Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Wood Lathes / Mills
Wood Lathes / Mills Discuss Wood Lathes / Mills here!
Old 07-14-2008, 08:18 AM
Art Ransom's Avatar
Art Ransom is on a distinguished road
Indexer software
For those running an indexer here is a email of Rich, rgoldner@iname.com, who has written 2 wizards so far for the indexer. I have been working with both and they are great. Rich is a retired programer who has been building CNC machine running Mach since Mach's early years. He also helped a friend upgrade his Legacy Ornimental mill to CNC. The perfect background for doing indexer wizards.
One wizard is to do spiral cuts. Designed mainly to do rope/barley twists. It allows to use A, B or C as rotational axis, do CW or CCW twists, select depth of cut, etc. Here is a 14" piece I did.
The other wizard will wrap a file around a cylinder using A, B or C as the rotational wizard. Both work great and he is going to write more.
The other option is http://legacywoodworking.com. They have released the beta version of a spread sheet that will do rounding, fluting and rope/barley twists. Price is $100. Right now it's only advantage over Rich's wizards is that it will do fluting. Hopefull Rich will fix that shortly.
Old 07-14-2008, 10:20 PM
ger21's Avatar
Are these wizards available for free? And can we download them somewhere?
Old 07-14-2008, 10:49 PM
Art Ransom's Avatar
Indexer wizards
No Rich will charge but price hasen't been set. He is giong to add more and I have encourged him to do a suite like New Fangle Solutions except for the indexer. Legacy charges $100 for their spreadsheat and it is not near as good. I tested the fluting wizard and found a minor problem which he should fix tomorrow. It will allow you to ramp in and out. Here is a test piece I did. Flutes are 3/4" wide, 4" long with a 1" ramp.
Old 07-15-2008, 11:34 AM
rgoldner is on a distinguished road
Check this thread:
New Mach3 indexer wizards available
Old 07-15-2008, 06:47 PM
Art Ransom's Avatar
Rich's website
Rich has setup a web site to handle purchase of his wizards.
http://www.wizardsbyrich.embarqspace.com:80/
Rich strikes again! He has written a rounding wizard. It will also do tapering. This a piece of 4x4 that has been in the wood pile for a few years so finish of cut is terible. Now the spiral and fluting wizards will have to be changed so they can be used on tapered work. I do a lot of spiral and fluting work on columns up to 18" by 10'. The rounding, fluting and spiral wizards are goining to save me a LOT lot of work! Profit just went up at least 15%. Talked with Rich about more enhancements and hopefully he will do more. Three weeks ago I bought the Legacy spreadsheet for $90 and was happy to get it. Now it is obsolete as the 286 computers
Haas VF1 & 5C Indexer lovell110 Haas Mills 3 12-08-2007 12:39 AM
SMW Indexer program. HELP!!!! protec General Metalwork Discussion 0 02-19-2007 08:21 PM
Nickolis indexer Kevin Taylor Work Fixtures and Hold-Down Solutions 0 12-09-2006 10:07 PM
indexer question pit202 Haas Mills 9 11-30-2006 11:45 AM
Indexer LPT - HELP! CNC Pro General CAM Discussion 3 03-11-2004 03:20 PM
