Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Wood Lathes / Mills
Wood Lathes / Mills Discuss Wood Lathes / Mills here!
Old 04-10-2008, 03:30 PM
buckey29 is on a distinguished road
Newbie needs help with router bit selection.
I've been on the forum for a while and always left a bit frustrated. I try using the search and never seem to find what I need. So I'm going to post although I'm sure the answer is here somewhere:
Q: I have a CNC router that uses a trim router as the spindle. I want to engrave, drill, cut both wood and acrylic. Also, I *may* do carbon fiber but prob not due to the dust, etc.
Is there a good resource for finding the bits: Endmills, rounded endmills, v-bits, etc. Which is good for what material, etc. Basically a guide for a newbie using hobby CNC router.
Thanks in advance for any help you can provide.
Chris
buckey29@yahoo.com
Old 04-10-2008, 04:42 PM
SCRAPWOTSCRAP is on a distinguished road
An informative site
https://www.onsrud.com/
Old 04-10-2008, 04:53 PM
Someone emailed me the Onsrud router bit guide in PDF format. Its got a LOT of information so I guess I should read it before asking any more questions. At first glance, though, it appears to be what I needed.
I plan on using a trim router to cut and engrave both wood and acrylic. For that primary usage I think I need to select a couple of good striaght bits (cutting) and V-bits (engraving). I may also pick up a 1/8" ball endmill for playing with some 3D created in BobArt.
If you use a home made CNC router with a trim router and have done any of the above with success, please post what bit(s) you are using. Thanks!
Chris
buckey29@yahoo.com
CNC Router Newbie IN-WondeR DIY-CNC Router Table Machines 24 05-27-2008 01:20 AM
Newbie question - End Mill Selection evena4 General Metal Working Machines 2 02-07-2007 09:17 PM
Newbie With Cnc Router Questions turntool Commercial CNC Wood Routers 7 09-20-2006 06:45 AM
Newbie..What router to get? billman DIY-CNC Router Table Machines 5 06-10-2006 10:58 PM
newbie help bit selection DrStein99 DIY-CNC Router Table Machines 4 10-25-2005 09:08 AM
