If my memory serves me correctly, I believe G77 will slave w to z and G78 turns it off. Been awhile..... "G77 ZW" then toggle off with a G78.
First of all, Hello everybody, this is my 1st post!! But been reading site for quite a while!!
Here's the deal...
I need to program a DMS router with twin spindles and a Fagor 8055M control.
Thing is I don't know what type of G Code would activate the second spindle (W axis) to act as the main spindle does (Z axis).
When I run a program for the Z axis, the W spindle begins to spin but it never moves up or down. I put G54 on Z axis and Put G54 on W axis as well but that would only lower the W axis (second spindle) to the same position as the main axis but won't follow the programmed path.
I have programmed the W axis to work by replacing al "Z" with "W" instances on the programmed G code, but I want to duplicate the programmed path on the main spindle so I can make 2 parts with the same set up (obviously on x axis there is a distance between Z and W axis).
Has anybody had an experience like this that would be kind enough to share his/her thoughts.
B.T.W I use mastercam for the programming part.
T.I.A.
Thanks for your reply ScrapWotScrap!!!
I will try this out tomorrow morning and report back!!
Thanks for your input Scrap
tried your suggestion and it worked great...so up goes my production
rate
thanks again and this is a great forum
keep up the good work
Glad it worked for you, actually....glad I remembered correctly, been a few years since I programmed the Fagors. Nice to know some of those brain cells are still functioning!
