| Wood Lathes / Mills Discuss Wood Lathes / Mills here! |
| Need a Technique to Set the Z Axis to Zero I have several routers running and decided to try a lathe. It's almost done. Need help with a technique to calibrate the tool tip to the center of the spindle. I'm using Mach 3 Lathe. This is probably a simple/stupid question, but I'm out here operating in a bubble. Thanks in advance. |
| The most straightforward approach is to take an OD cut and a face cut on a piece of stock. Enter the Z coordinate for the face cut into the Z tool offset table. Enter the X coordinate for the face cut into the X tool offset table and then add half the measured diameter of the OD onto this. That puts X on the spindle centerline. NOTE: In saying add half the diameter I am assuming your machine is going to display machines coordinates as radial values for the X axis; if the machine displays the X position in terms of diameter then it is the full measured diameter that is used.
| Thanks Geof, WOW, That was quick. Thanks for the help. |
| tool making technique | sharathchandar | General Metalwork Discussion | 0 | 10-24-2007 09:05 PM |
| roughing/finishing technique | fpworks | Hard and High Speed Machining | 14 | 10-14-2007 12:33 PM |
| Ball-Bar measuring technique and mapping ballscrew | AKFALAR | Linear and Rotary Motion | 2 | 05-06-2007 09:20 PM |
| What's your technique for routing out parts | originator | General Metalwork Discussion | 4 | 02-04-2007 02:33 AM |
| Control Technique Digitax DBE 750 AC Servo-Drive | GalaticDan | Servo Motors and Drives | 6 | 09-16-2005 07:32 AM |
