Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Wood Lathes / Mills
Wood Lathes / Mills Discuss Wood Lathes / Mills here!
Old 08-07-2007, 07:14 PM
mattn is on a distinguished road
Question Suitable router for a Rockcliff CNC Machine made from 18mm thick MDF
I am half way through building a Rockcliff CNC machine (http://www.rockcliffmachine.com/cnchome.htm) in 18mm MDF like they suggest and I was wondering what would be a suitable router to use on this machine. I live in Australia and would like to be able to purchase a suitable router for it in Australia.
Thanks in advance.
mattn
Old 08-14-2007, 06:35 PM
Coogrrr's Avatar
Coogrrr is on a distinguished road
Hope this helps.
I would suggest this one as it will have the power you want and many people including myself have now used them in many different machines with very consistent and good results. It will fit on the machine but would be larger than the hand router that machine would normally use. You could look to the Hitachi hand router also.
http://www.tylertool.com/hitachi106.html
Coog
Building Stage:[xxxxxxxxxxxxxxxxxxxx] 105%
Finishing Stage:[xxxxxxxxxxxxxxxxxxx-] 95%
Old 08-15-2007, 12:14 AM
Great post
Thanks for the great post. I am also now looking for routers which are a bit smaller physically but are also a bit lighter.
from mattn
Rockcliff Router Build lgroulx200 Rockcliff Machine 283 07-21-2009 08:34 PM
Rockcliff Router Build, MFD CheekieMonkies CNC Wood Router Project Log 16 08-14-2007 06:52 AM
One out of 18mm MDF in the Netherlands Witsenburg CNC Wood Router Project Log 9 07-08-2007 03:20 PM
Need a suitable machine Moesian Mechanical Calculations/Engineering Design 0 08-14-2005 12:49 PM
