Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Wood Lathes / Mills
Wood Lathes / Mills Discuss Wood Lathes / Mills here!
Old 02-24-2007, 10:40 PM
ronkm is on a distinguished road
help with cnc lathes
Im a fishing plug builder and would like to know if anyone can tell me what type of cnc lathe I need where to find in the 3000$ RANGE OR UNDER. I now do them on a stock jet lathe 6'' plug takes me about 4 mins .Would a cnc save me time and man power? WHOEVER THANKS FOR THE HELP.
Old 03-04-2007, 08:54 AM
Art Ransom's Avatar
Art Ransom is on a distinguished road
fishing plugs
I am a profesional turner and have built my own CNC to do columns up to 24" by 10'. The only way to beat that speed would be to go with 100K+ machine. Instead concetrate on improving your turning. Go with a single point spur drive, see http://www.turningaround.org/204SpurDrive.htm, turn at max speed and use a skew. I can do a 1.25" by 18" dowel in 4 minutes with tolerances of .01" out of fir. Don't be gentle, get aggesive!
Old 05-19-2007, 05:36 PM
Blaise is on a distinguished road
Are they all the same profile? Aren't there duplicating lathes out there??
A router lathe can also duplicate profiles from a template Checkout the New Router Handbook by Patrick Spielman for some examples.
Old 05-23-2007, 11:00 AM
low_48 is on a distinguished road
If they are the same profile you could look into an old turret lathe. Have a special knife ground and attach it to the lever activated cross slide. The knife will need to have the profile EDM cut down the face of the steel, and then compund angle ground on the lead edge. It will shear the material as it slides/cuts past the stock. This will duplicate the action of a back-knife lathe and will cut the profile in one cut. You can also then have a drill bit in the turret and drill the hole for the swivel before turning. Should be able to make the cut in less than a minute.
SL-30 lathes 9566317 Haas Mills 3 03-31-2007 11:36 AM
New to lathes and have a few ????? Mousehouse Mini Lathe 16 02-19-2007 08:26 PM
MetalWorking Machines / Lathes / Mini Lathes widgitmaster Suggestions for the CNCzone.com site. 0 01-04-2007 06:48 PM
Darn near FREE LATHES!!!! - 2 lathes, gotta go NOW! mxtras General Metal Working Machines 0 03-22-2006 01:43 PM
Lathes, what’s the difference between the different types of lathes out there? MrRage General Metal Working Machines 9 03-15-2006 03:07 AM
