Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Wood Lathes / Mills
Wood Lathes / Mills Discuss Wood Lathes / Mills here!
Old 02-13-2007, 01:01 PM
drumbuilder is on a distinguished road
help in construction!
can somebody help me with these anibody with some plans!! thanks!!
Old 02-13-2007, 01:19 PM
toneV8 is on a distinguished road
Šta je to na slici.
Old 02-13-2007, 01:23 PM
to ti je tokarac za drvene shellove znas li sto o konstrukciji toga??
Old 02-13-2007, 04:36 PM
sailfl is on a distinguished road
More information
I think you will get a better response if you provide in more details what kind of help you are looking for.
Old 02-14-2007, 05:40 AM
i need some plans for building this!! I am interested only how to build a jig on that table so I can fix the drum shell on it!!
Old 02-23-2007, 02:43 PM
JasonD is on a distinguished road
Looks pretty basic, your main issue would be finding the metal for the jig. I would think that it could be done in wood as well, (plywood 2 or 3 pieces of 3/4 stuff epoxied together)
Then from there, find out your circle radius and start drilling the boltholes that will hold your drum on.
Looks like they have 7 bolts threaded through to catch the inside.
EDIT: If your ONLY plans were for drums.. I would think that you could build it completly out of plywood and have the pulley bar sitting on top of a few bearings on top of the wooden plywood box. The arm for holding your carving tools could also be bolted right to the box.
Make a square box, sealed in on all sides, bolt the pulley and bar onto bearings clamped to the top, then bolt a metal arm coming out to hold your chisels..
I have plans that show how to make a wooden lathe out of all plywood & other parts available at a hardware store.. drop me a PM if you want them.
Old 11-23-2007, 09:10 AM
Drakkn's Avatar
Drakkn is on a distinguished road
PM me as I am getting into drum building also - I have some plans for a woodworking lather.
Regards
Tony
Drakkn Guitars http://www.uk-guitarshop.co.uk
Old 12-15-2007, 11:59 PM
mhickler is on a distinguished road
I build banjo rims - similar
Check out my website... hicklerbanjo.com. I have a four axis lathe that I made myself. It's not exactly the same, but it works. I have some pictures and plans, though not complete for the CNC prototype. I'll help you if I can.
- Mark
Old 12-20-2007, 06:24 AM
Drakkn's Avatar
I guess your plans could be adapted to make snare drums ?
I know I make guitars but I am also being asked if I can make drums as well
Old 12-20-2007, 03:19 PM
email me and I'll do what I can to help. My plans can be adapted, but you can also adapt a standard wood lathe.
mhickler@gmail.com
  #11   Ban this user!
Old 12-20-2007, 03:45 PM
Drakkn's Avatar
mhickler@gmail.com
Cheers - I have not even made the lathe yet - just finished my cnc machine - probably cant adapt that though ?
  #12   Ban this user!
Old 12-20-2007, 03:58 PM
Can you send pictures?
Tyre Construction For Models laboratorio Hobby Discussion 3 12-18-2006 09:20 AM
Spindle construction georgebarr General Metal Working Machines 9 04-23-2004 02:15 PM
Construction update! chuckknigh DIY-CNC Router Table Machines 35 02-05-2004 12:06 AM
construction plans owhite DIY-CNC Router Table Machines 0 01-19-2004 11:07 AM
I-Beam construction chuckknigh DIY-CNC Router Table Machines 5 08-14-2003 01:18 AM
