Results 1 to 8 of 8
Thread: Approx Lathe Price
    Registered thkoutsidthebox's Avatar
    Nov 2006
    Ireland
    Question Approx Lathe Price
    Hi all,
    Does anyone have any idea how much this lathe would cost. Im thinking its probably about €8000 - €10,000 and I dont want to e-mail them because I dont think I'll be buying one, unless it comes in under €3000, which is why Im asking!
    Does anyone have any idea how much this would cost?
    http://www.hapfo.co.uk/products/ap5000m.htm
    Thanks.
    L8rs.
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by thkoutsidthebox View Post
    I think you're guess is pretty close.
    Nov 2006
    Ireland
    Thanks ger. Thats good to know. I haven't bought my 1st lathe yet so I figured someone whos seen a few different types and models come and go would have a better idea of the price.
    Mar 2003
    I'm just guessing as well. But I know you can spend $5,000 on a good standard lathe.
    Registered Art Ransom's Avatar
    Jun 2005
    lathe cost
    Been a while since I looked at buying one but I thinkthat the Halpo was $25,000 plus. I couldn't find any commercial machine anywhere near what I could afford except the Legacy ornimental mill. After 3 years with the Legacy I needed something with more features so I started building my own CNC mill. Turns out that the hardest part of the process is getting time to work on it. Expect to have A axis operational within 2 weeks. If you have the need for a Halpo but can't afford it you should consider building a CNC mill. Look at my site www.turningaround.org for details. I will be adding to it as I go and will be glad to help anyway I can.
    Nov 2006
    Ireland
    Im thinking less than half of that $5000 Gerry for my lathe. I dont see it being a mainstay of my business, only for intermittant pieces. Although there is one thing I'd really like to be able to do....see below....
    Thanks Art. I had a look at your site a few times before. You do some really great looking pieces.
    Thats one beast of a machine turning the 9 1/2 ft column. Hope it didn't come loose!
    .....I'd really like to be able to turn spiral ropes on columns but from my understanding a cnc lathe is a necessity for this. Is this correct?
    A cnc lathe is outside my budget at the moment, so I guess I'll just do without, unless someone can tell me how to turn them economically and manually.
    Jun 2005
    ropr twists
    You can get a Legacy but the 1800 will cost 5K This is my cost on my DIY mill/lathe/router where mine will do 24" by 12' columns and more and the Legacy will do 11" by 8' columns. I built my machine because of the limintations of the Legacy.
    Nov 2006
    Ireland
    I dont see myself needing a lathe larger than 48" at the moment. Although I do have ideas that I could put into fruition with a larger one at a later date.
  • Tags for this Thread
