Results 1 to 7 of 7
Thread: True 4th Axis vs Fake 4th axis?
    Sep 2007
    I have a chinese 3 axis router, and to my dissapointment, the company says I cannot add a 4th axis since I have DSP control.
    I am ordering a rotary attachment and have to cannibalize the Y-Axis for rotary control. Can someone explain to me the disadvantage of this when creating 3 dimensional objects? I don't want to make only cylinders, can I still create some complex objects with a fake 4th axis?
    Thx
    Apr 2004
    Oakland CA USA
    You should be fine
    It's going to be more trouble switching back and forth from 3-axis mode, but there's no inherent problem running a 4th (A) axis motor off the same driver as is used for the Y axis motor (as long as they're the same type of motor). You will need to figure out a way to fix the Y axis in position at the Y=0 point, though, since it will tend to freewheel if it's not held by the motor.
    Just switch the Y axis leads to the A axis motor (assuming they're compatible) and reassign the Y axis to A. I'm not sure what software you're using, so I can't give you detailed instructions on how to do this, but if it's difficult you can alternatively just edit your G-code to substitute Y for A.
    To generate the G-code, you can use DeskProto (it's free for the first month). Pick an "along X" 4th axis strategy, and it should work fine, even for relatively complex objects, since only the X, Z and A (formerly Y) axes are used.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Quote Originally Posted by microbeast29 View Post
    Thx
    Apr 2009
    england
    dsp control
    can you just tell me what dsp control is and what the better control set up is? I've searched but it all seems to simply state it uses dsp to control rather that say what its limitations are.
    is it limited to how many axis movements can be made at once?
    Registered Ashish B's Avatar
    May 2009
    India
    See, 4th axis is nothing but a indexing head which can rotates (independtly) & slowly in combination with tool. So, simultaneous cutting & rotating (of Job) happens.
    A simple example to give you is how would anyone machine a screw of 200 mm pitch...
    The answer is only 1...(4th axis attachment)
    Hope it helps.
    Registered 4dwood's Avatar
    Jul 2011
    Russia
    I have a 4th axis two parallel spindle (homemade) machine, of 4 coordinates are used all, we make cabriol legs, and in most cases without 4th coordinates is impossible.
    Excuse for my bad English.
    Sep 2008
    Quote Originally Posted by dominicburke200 View Post
    DSP = Digital Signal Processing
    Without knowing more about your controller I really can't give you much info on it, but I see no reason you sholdn't be able to use the X or Y axis for the A. Software can be tricked into carving a flat pattern onto a round stock.
    Registered MonoNeuron's Avatar
    Aug 2003
    I use a DSP for my laser control and swap out the Y axis for the A (rotary) axis.
    I save a separate config file for rotary and flat cutting after setting them up and then just select the config I need for a particular type of job and import it into the DSP.
    It's very easy to do but you need to remember which one you used after swapping them back. :-)
    I use 4 pin plugs made for microphones and wire them up so I just have to plug in which axis I need after setting it up before hand. Do turn off the machine BEFORE you disconnect the leads as most stepper drivers don't like to have nowhere for the electricity to go and will burn out.
    Rich.
    I am not completely useless.......I can always serve as a BAD example.
    1. Grinding and unexpected axis movement if rapiding 2 axis
      By DarkSabre in forum Taig Mills & Lathes
      Last Post: 03-26-2010, 12:37 AM
    2. New~ Glassware anti-fake laser flying sub-engraving machine
      By 3dlasermachine in forum Product and Manufacturer Announcements
      Last Post: 08-20-2009, 12:46 AM
    3. Compare Catia and MCX2 for multi axis lathe/4 axis mill
      By bob1112 in forum General CAM Discussion
      Last Post: 10-10-2008, 08:15 PM
    4. One axis (z-axis?) computer controlled testing device
      By TsThorsell in forum Stepper Motors and Drives
      Last Post: 02-07-2008, 01:38 PM
    5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
      By the__extreme in forum CNC Wood Router Project Log
      Last Post: 02-26-2007, 03:58 PM
