yah thats a possiblity...was hoping for a 2" OAL thats what all of my up cuts currently are
Not the same brand but I did find this 1/8" downcut with an 1/8" shank on EBay. Seems deccent quality! https://www.ebay.ca/itm/151926815022. I should add that the seller said it would work fine for wood, which is how I intend on using it.
Most of the major router bit manufacturers don't make 1/8" shank bits, because handheld routers don't have 1/8" collets..i would like an 1/8' down cut as well with an 1/8 shank...doesnt seem to exist
Ebay is your best bet for 1/8" shank tools. You'll pay a fraction of what you'll pay anywhere else.
UCCNC 2017 Screenset
I noticed that Lee Valley is offering 1/8" down cut bits for dremels, I assume they are fine for CNC routers. Not sure on the OAL, but here's a link Mini Downcut Spiral Bits - Lee Valley Tools
And here's a similar tool for 20% of the price:
10 1 8" 1250" Carbide 2 Flute Endmills Soft Plastic Downcut 1650 1250 500 | eBay
Looks like the same seller as my earlier post with a volume discount. Good price!
I found a downcut bit was my only way to run cutting profiles in thin sign work in 1/8" PVC sheet (Sintra board). Its a really flimsy sheet and my vacuum couldn't keep the sheet flat with an upcut. The upcut force would lift the sheet from the spoilboard and screw up the cut accuracy. Are there compression bits that would place the compression center in the middle of such a thin sheet?
ordered the 1/4 yoniko and will order an 1/8 and 1/6 from fleebay...to save my sanity from sanding
Anything under 1/4", I keep my depth of cut to no more than the tool diameter.
Feedrate depends on what you're doing, could be anywhere from 75ipm to 300ipm. 12,000-18,000 rpm.
With a 3 flute, keep the rpm lower, and the feedrate higher.
Lately (which is past 3-4 years), for wood, I use single-edge endmills almost exclusively for most any tooling 1/4" or less. Creates larger chips, and ejects them a lot better. Plus, you can run your spindle at higher speeds, where you'll have more HP...
Running at higher speed would help the speed control on my router to keep up...
I saw single flute dow cut in a catalognat work. I think I'll order one to try. I think it's FS Tools. Are these good cutters?
My new router is supposed to have 2hp but at lower rpm my old 1hp Makita had better speed control so it "felt" like it had more power at low speed...
I really need to complete my PID but sometimes life gets in the way.
Yes, FS tools are good, and made in Canada.
Probably not the cheapest, though, but nothing is, when you live in Canada.
