Wood Working Tooling
Page 1 of 7 1234 ... LastLast
Threads 1 to 20 of 135
Forum: Wood Working Tooling
Tooling specific to Wood Working
  1. Need Help!- Flattening / planing hardwoods - best bits?
    Started by bking3132‎, 12-08-2017 07:41 PM
    amana, ideas, i’m, news, slab
    12-08-2017, 08:28 PM Go to last post
  2. Question which router?
    Started by rljk‎, 08-03-2017 10:57 AM
    choose, cnc, dewalt, evs, router
    08-03-2017, 11:18 AM Go to last post
  3. Good tool for solid surface
    Started by Biggs427‎, 07-05-2017 10:26 AM
    chinese, cnc, cutter, cutters, upcut
    07-06-2017, 07:13 PM Go to last post
  4. Tool for milling OSB sheets
    Started by fabhouse‎, 11-15-2011 06:15 PM
    not
    06-14-2017, 05:36 PM Go to last post
  5. Problem- V-bit rough fiinish in softwood
    Started by djoe‎, 06-12-2017 11:25 PM
    06-13-2017, 11:21 PM Go to last post
  6. Cutter Heads
    Started by caseymx‎, 06-12-2017 10:34 PM
    06-12-2017, 10:56 PM Go to last post
  7. Question Newbie- Anyone use down cut bits for wood cutting...
    Started by airbrush‎, 06-22-2016 11:44 AM
    3 Pages
    1 2 3
    05-24-2017, 07:42 PM Go to last post
    05-24-2017, 07:15 PM Go to last post
  8. Anyone tried O-flutes on Wood? How about ZRN coating?
    Started by GJeff‎, 12-20-2016 02:24 AM
    coated, cutting, o-flutes, wood, zrn
    05-24-2017, 07:03 PM Go to last post
  9. BEST SHELL MILL / FACE MILL FOR LAMINATED HARDWOOD
    Started by Luftegrof‎, 05-19-2017 12:21 PM
    75%, face, mill, spindle, step
    05-19-2017, 02:01 PM Go to last post
  10. Newbie- advice on the full process
    Started by r-johnson‎, 05-15-2017 01:54 AM
    cnc, process, roughing, run, tool
    05-16-2017, 04:20 PM Go to last post
  11. Best bullnose/ball bit for the job
    Started by Krlerma‎, 02-28-2017 01:19 AM
    2 Pages
    1 2
    03-05-2017, 12:14 PM Go to last post
  12. Correct Terminology
    Started by caseymx‎, 11-15-2016 08:55 PM
    11-15-2016, 08:55 PM Go to last post
  13. Newbie- What bits in your kit?
    Started by hyperionfall‎, 09-25-2016 02:35 PM
    bit, bits, cnc, kit, signs
    09-25-2016, 06:01 PM Go to last post
  14. New Machine Build- Spindle Moulder Head 5083 Alloy
    Started by boydage‎, 09-05-2016 04:23 AM
    09-05-2016, 04:23 AM Go to last post
  15. Build Thread- Spindle Moulder Profile Blades
    Started by boydage‎, 07-13-2016 07:49 AM
    alloy, cnc, moulder, profile, spindle
    07-25-2016, 12:10 AM Go to last post
  16. Problem- cut quality on melemine
    Started by Benaiah‎, 07-06-2016 04:12 PM
    cabinet, cnc, edge, quality, sides
    07-07-2016, 04:52 PM Go to last post
  17. Straight bit more accurate than spiral?
    Started by stefon‎, 05-04-2016 02:45 PM
    accurate, bit, normal, spiral, straight
    05-04-2016, 08:58 PM Go to last post
  18. Speed/Feed/Depth for Solid Wood
    Started by SteveS‎, 04-10-2016 02:00 PM
    3/8, ced, chipload, whiteside, wood
    04-10-2016, 04:09 PM Go to last post
  19. Speed/Feed advise for 1/2" bit to cut MDF / BB Ply / MDO
    Started by SteveS‎, 04-05-2016 06:26 PM
    2 Pages
    1 2
    bit, cut, cutting, flute, mdf
    04-10-2016, 08:42 AM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 3 users browsing this forum. (0 members & 3 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
