Homemade Rotary Press Drill Frame Stage here:Homemade Rotary Press Drill Tools Drills DIY Wood Horizontal Vertical Drilling
1 hand drill tools
1 pcs Aluminium 100 mm x 80 mm x 20 mm make hole 42 mm for hand drill tools
Materials for Z Axis slide 100 mm travel
2 pcs Aluminium 42 mm x 82 mm x 10 mm 2 pcs rod shaft 12 mm x 200 mm cnc linear rails CNC rod
2 pcs Aluminium 80 mm x 80 mm x 8 mm
4 pcs LMK12UU 12mm flange bearing CNC Flange Linear Bearings Flange 1 pcs Ozito or Dremel rotary hand tools
More Good Projects Homemade Nice Work for DIY Handmade here:
