Hi I have a rotary cnc machine that uses nc studio. When I run a gcode from aspire the g00 part of the code seems to stall the rotary axis then runs fine when cutting. I was reading through the code and the federate is the same as cutting feedrate I.e f3000 . When I edit the code and change the g00 to feed at f1000 and cut at f3000 the problem doesn't happen. So the stalling only happens during the g00 part of the Code. It seems to be ignoring the connection and linear acceleration I have correctly set for cutting. Is there any setting in nc studio that will make the g00 respond to the linear and connection accel set in nc studio or is there any other reason this would happen?
thanks in advance
