Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Welding, Brazing, Soldering, Sealing
Welding, Brazing, Soldering, Sealing Discuss Welding, Brazing, Soldering, Sealing technique's here.
Old 04-13-2005, 04:27 PM
bb99 is on a distinguished road
Notching Steel Plate
Hi All,
I’m working on a metal welding bench. I want to add some 1/8” steel plate to the top but I’d like to notch the edges for a better fit. I’m also thinking of another project which will require me to remove a 1”x1” square from the center of a 1’x1’ plate. What is the best way to cut these notches/holes (best defined as cleanest/straightest but not necessarily the fastest)?
Thanks,
bb99
Old 04-13-2005, 04:38 PM
2muchstuff is on a distinguished road
The cleanest/ straightest, which happens to be the fastest is water jet cutting. The notches on the edge, a hack saw and a file. The hole in the middle, a torch or plasma cutter followed up with a file.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 04-14-2005, 11:37 AM
Hi 2much!
Thanks for the information.
bb99
There are 10 types of people in this world; those that understand binary and those that don't.
Old 10-13-2005, 08:31 PM
Possum is on a distinguished road
i agree with 2muchstuff. plasma will be your best bet if you can afford it or borrow someone elses. using oxy-fuel takes a little skill to get a perfect cut.
[IMG] code is Off
DIY Z axis 0 plate. It works perfect! balsaman DIY-CNC Router Table Machines 64 02-20-2010 11:52 PM
How to weld plate to tube at 90 degrees? coolman Welding, Brazing, Soldering, Sealing 12 12-23-2004 03:03 PM
Drilling hardended steel - update DJ Morrow General Metalwork Discussion 3 11-29-2004 01:42 AM
why not steel? NeoMoses DIY-CNC Router Table Machines 15 09-11-2004 10:14 PM
Cutting 3/8 steel plate BlueC General Metalwork Discussion 2 05-21-2004 11:06 PM
