Results 1 to 5 of 5
Thread: thinking of building a tig welder
    Apr 2009
    i was going to build a rectifier for the power source if there are any tutorial on that i could use the help
    and i would use this as the control board http://diy-welder.com/linear.shtml
    but it says scratch start is there a way that i wouldn't have to do that like a real welder i thought with dc getting it close enough it would start
    any tips?
    Registered mc-motorsports's Avatar
    Feb 2007
    You need 'high frequency' to avoid the scratch start. Otherwise, depending on the diameter of the tungsten, put enough amps to it and it will jump a small gap, problem is it's going to tear on your tungsten and probably blow a hole in thin gauge material.
    Miller is now saying touch the tungsten, pedal on for 2 seconds, lift the torch. Actually scratching the tungsten #1 scratches your part, #2 contaminates the tungten more than touch, pedal on, lift.
    MC
    Apr 2009
    Ive got a wicked idea not very practical but if you had a piece of tungsten next to where you start scratch on it bring the arc over and weld probably unpractical but it could work
    Feb 2007
    Quote Originally Posted by patreusch View Post
    honestly, scratch start isn't that bad... But that is still a practical idea, can't think of a reason it won't work, it would be worth a try!
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    Get yourself a piece of copper plate to use as a scratch pad, less - to - no contamination. Put it beside your joint and start the arc on it, swing off the copper onto the joint to be welded.
    Why would you bother to build a TIG machine when bottom end machines can be bought so inexpensive?
    www.integratedmechanical.ca
  1. welder
    By popppop in forum General Electronics Discussion
    Last Post: 03-31-2009, 02:58 PM
  2. Thinking of building a Joes CNC 2006 in Brisbane Australia
    By ClaudioG in forum Australia, New Zealand Club house
    Last Post: 04-27-2008, 01:43 AM
  3. TIG welder DIY
    By MrWild in forum Welding, Brazing, Soldering, Sealing
    Last Post: 10-25-2007, 07:34 PM
  4. Thinking of building a small CNC plasma table....
    By CDIZX3 in forum General Waterjet
    Last Post: 09-11-2007, 09:43 PM
  5. Welder
    By Mr.Chips in forum Welding, Brazing, Soldering, Sealing
    Last Post: 02-07-2007, 03:04 PM
