Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Welding, Brazing, Soldering, Sealing
Welding, Brazing, Soldering, Sealing Discuss Welding, Brazing, Soldering, Sealing technique's here.
Old 12-22-2004, 11:44 PM
nervis1 is on a distinguished road
TIG recommendations?
I need a TIG machine. 1/4 inch max will be my envelope, mostly AL so I'd like square wave, no need for water cooling, I have a 60 amp 240V circut but I'd like to be able to run from 110V if needed (I know some of the Millers will do this). Anyone have a specific model to recommend?
Old 12-23-2004, 06:05 AM
*Registered*
ESjaavik is on a distinguished road
You should consider renting one first.
Welding aluminum is very different from steel, so you may not know your priorities until tried. For one, I think you will want water cooling for 1/4", and lots of current. If price is a concern, look for an old industrial unit. They have now come down in size/weight quite considerably, with many automatic features, and many businesses want these new units (and can afford them). So if you have space, you may get a good one for a fair price.
Old 12-23-2004, 09:42 AM
About how many amps would I need to do 1/4"? I'm using this in a garage so that may be a limiting factor.
Old 12-23-2004, 10:26 AM
an0n is on a distinguished road
I would say 250 - 300 amps since welding alu really takes lots of current
Old 12-23-2004, 11:05 AM
Well looks like that idea is out the door LOL.
Old 12-23-2004, 05:19 PM
I just ordered a Miller Dynasty SD with the torch kit from Cyberweld. I stopped by a local weld supply place and they told me it will do just about anything only limited by my circut. They did say that with 1/4" I'll need a water cooled torch like was stated above. Maybe later. Their price as 1k higher than the internet, I wanted to buy local but that was just too much!
I'll let you all know how it works, and even better how it is on a noob like me.
Old 12-23-2004, 05:26 PM
Very nice, I havent tried any Miller unit, What kind of amerpage does it have at max?
Old 12-23-2004, 05:30 PM
http://store.cyberweld.com/mildyn200sda.html
Heres the link.
Says 1-200
I'll just have to adjust my projects to fit as I just don't have the current, or space for a bigger unit.
Old 12-23-2004, 05:46 PM
that seems like a very nice unit, and the price was awesome
it'll be fun to hear how it is to weld with..
Try welding some normal iron first, and getting the feel for adding filler rod, and when you are starting to get the coordination right then move to welding alu..
remember to clean the alu before you weld otherwise it'll be really really hard to get any good looking welds ^_^
Good luck, I am looking forward to hearing about your progress
Old 12-23-2004, 06:11 PM
ty1295 is on a distinguished road
I have had a miller 180sd for 3 years now. Used the piss out of it, works great.
Even welded up to 1/2" thick aluminum once, although preheating is a must.
I wouldn't have an issue doing 1/4", now if you said you needed 10ft of weld done at one shot, the air torch aint going to cut it. You would want to stop and let it cool. I have had the torch hot enough even gloves didn't help much.
You will need 70 amp breaker for the 180sd though, or be very careful in your max setting.
Aluminum is the worst to weld in terms of power requirements, so just be aware of that.
  #11   Ban this user!
Old 12-24-2004, 12:45 AM
http://www.millerwelds.com/education...es/story71.php
Draws 16 amps 230 at full tilt? Cool. (third to the last paragraph).
Old 12-24-2004, 03:37 AM
*Registered*
I didn't see it having slope up/down control. Then you should have remote control Foot pedal. Or do as I did and make a control knob mounted on the handpiece. It's just a potentiometer.
If you don't slope down, there will be a crater at the end of the weld.
[IMG] code is Off
Welding TIG Stainless Steel w Argon tutorial needed. Calico Welding, Brazing, Soldering, Sealing 5 09-14-2009 06:33 AM
90Amp Arc / TIG Conversion barkster Welding, Brazing, Soldering, Sealing 9 11-23-2006 12:11 PM
Questions about TIG jrc347 Welding, Brazing, Soldering, Sealing 8 11-10-2006 10:40 PM
NEwbie Help, is this too thick for my TIG ? Calico Welding, Brazing, Soldering, Sealing 19 09-29-2005 07:16 PM
stepper motor recommendations mtechserv Stepper Motors and Drives 0 11-12-2004 11:47 PM
