Results 1 to 2 of 2
Thread: Bevel Sizes
    Mar 2006
    Bevel Sizes
    Hoped for simple chart on how large weld bevel should be. Didn't happen.
    I'm designing a fabricated steel machine base which will be filled with Epoxy/Granite. (end customer buys by the pound).
    Top plate is 1 3/4" thick HRMS in flat horizontal position. Side plate is a vertical 1" thick HRMS. The weld is to 100% penetration from one side.
    My inclination is a 3/4" 45 deg. in the 1 3/4" top plate. ????
    Also, do I require a "throat" or whatever it's called between the top of the vertical plate and the underside of the top plate? If so, how wide should it be?
    I have a book titled "The Procedure Handbook of Arc Welding". This book is very informative on fillet welding but doesn't have much on groove welding in this type of position.
    The reason for this weld is because it's not very accessible from the inside so fillet welding from both sides isn't practical.
    Dick Z
    DZASTR
    Mar 2006
    Never mind, I found it on the internet.
    Thanks anyway.
    Dick Z
    DZASTR
  1. Can you make Bevel Gears??
    By sleepy23 in forum Employment Opportunity
    Last Post: 04-28-2010, 08:39 PM
  2. Plasma Bevel
    By pricer in forum General Waterjet
    Last Post: 06-19-2007, 10:05 AM
  3. 45 degree bevel on angle iron
    By Rypper in forum DIY CNC Router Table Machines
    Last Post: 11-14-2006, 01:00 AM
  4. What tool is best? Bevel/Chamfer
    By dneisler in forum General Metalwork Discussion
    Last Post: 11-29-2005, 10:44 AM
  5. Bevel Gear Calculations
    By ronmarkum in forum Mechanical Calculations/Engineering Design
    Last Post: 11-19-2005, 10:17 PM
