Results 1 to 7 of 7
Thread: HF 91811, the $200 wonder
    Oct 2005
    I bit the bullet and bought one. After playing with it over the last few weeks, my impression is, "They got all of that for just $200?" Although it doesn't state this in the ads, It does have pre and post gas flow. The start isn't done with striking the surface to innitiate an arc. There is some sort of low voltage/amperage prestart. You touch the tip to the work, and lift it off the surface. The pre-gas flow starts and then the main amps kick in starting the arc. Soft start?
    Something interesting is that the weld power can be controlled by twisting the power control knob during a weld. I've been brain storming with another HF owner and we seem to have found a sort of holy grail. Foot control. Someone said it couldn't be done. Others said the electronics were proprietary. Smarter men have failed, it is time for a stone axe approach. My friend got his together before me, but here is a good idea of what we are doing.
    A delrin pulley is made with two shoulders. These act as bearing surfaces for the mounting plates. Concern about pot life was raised if the pot had to take the entire pulley force. The cable is a bicycle shift cable. The interesting return spring is from a broken motorcycle kickstarter. Mine is getting a standard coil spring. Only one hole gets drilled in the case foir the cable end.
    The torch head is a bit cheesy, but seems to do the job fairly well. Is it on par with a $1,600 Miller? Nope, but it is very capable for what it does cost. If you have a budget and want to get into TIG welding without the big outlay of cash, here you go. You will also need a flowmeter/regulator as the unit doesn't include one. Found one on eBay for $35 delivered
    Oct 2005
    Addendum
    The problem with cratering at the end of the weld has been solved with this adaptation. Let up on the pedal and draw back slightly to extingiush the arc, and the post flow stays on the weld.
    Gold Member
    Mar 2005
    Glad you posted this, I have been looking at them too and wondering if it would be any good.
    I just wanted a tig to play with at home, now I will get one
    mike
    Nov 2007
    I had one for awhile but ended up selling it. It does work pretty well for a $200 tig. I easily made a real foot control. I got a guitar foot pedal on eBay for less than $20. I swapped out the pot for the correct range, I think it uses a 10K ohm. It is a bit tricky to setup, as the amp control use both halves of the pot at the same time, ie, one side decreasing and one increasing, just be methodical when doing the wiring.
    Another aspect on mine was the pot I got had a 270 degree sweep, but the foot pedal was a bit shy of that. So I could set it up to give amperage all the way up, or all the way down, but not both at once. A better fit for the pot to the foot pedal would solve that problem.
    I sold it because the unit does not come down to low enough amps for the light sheet metal work I wanted to do. I have heard a good review of Grizzly's $500 tig with pulse control, and I am going to that next. The poster previously had the HF tig, and found the Grizzly to be superior in starting and had a more stable, less agressive arc.
    Dennis
    Jan 2008
    Quote Originally Posted by mixdenny View Post
    It is a 10K linear taper pot. You could substitute another pot for an external control.
    For a foot control I might consider using a slide pot.
    That could be addressed electrically or mechanically. The 10K pot is part of a simple voltage
    divider spanning between 19%..60% of the internal PWM controller's 5V reference.
    There is also an internal 50K trimpot used to set the heat range which could be adjusted to
    increase the low end range. In any case the PWM controller is an SG3525 which is pretty
    simple to massage to get what you're after.
    Jan 2008
    Quote Originally Posted by MrWild View Post
    Well sort of. The pre flow actually depends on the user to keep the electrode in
    contact with the work long enough to effect "pre flow". When the electrode is
    lifted off the work the PWM starts and initiates the arc. For the first second +/- the
    heat is fixed to insure an easier start when the running current is low. After this initial
    fixed heat the PWM will be driven at the running heat selected via the front panel
    pot.
    Yes, it is just applying a voltage to the PWM error amp which except for the start
    current above is variable during the weld operation.
    Ha. That's the one thing this welder's electronics are not -- which IMHO is a huge benefit
    for those who would like to conduct some experimentation. The design is fairly vanilla
    and associated components are industry standard. On more mainstream equipment
    you're going to be looking at reverse engineering a microcontroller based approach vs
    the Kende discrete design. Although a microcontroller design is going to provide far
    more features than are available in this controller.
    I'd opt for the external pot solution. There is an internal transformer which isolates
    the control circuitry from the mains so that shouldn't be a concern.
    The actual control circuitry resides on a small PCB which contains the PWM controller
    and start/timing logic. One could remove the existing board and substitute a more
    comprehensive microcontroller based solution to provide additional heat control
    features found in substantially more expensive equipment. The logic which implements
    the post purge "feature" would be one of the first things I'd toss out in favor of a
    more general approach.
    Another possibility is a slight modification to the output transformer to furnish
    AC current. This is a bit of a hassle as you'd need a means to switch the high
    current secondary winding between the existing center tapped configuration
    and that of two separate but parallel windings.
    Nov 2007
    Quote Originally Posted by uhmgawa View Post
    Thanks for the insights on the electronics. A slide pot would be a good choice if you are building a foot control from scratch. The guitar foot pedals are already set up with standard rotary pots. They use a gear track attached to the pedal to spin the pot. Very easy to change out the pot, and my foot control cost less than $25 total.
    1. harbor freight 91811 Tig
      By 61-63 in forum Welding, Brazing, Soldering, Sealing
      Last Post: 09-23-2007, 10:53 PM
