Results 1 to 7 of 7
Thread: carbon steel welding
    Jul 2007
    I have a holding tank that is made out of carbon steel and it has developed two pin sized holes which are now leaking water. This tank is not a pressure vessel it is a tank with a heated water jacket. Anyway I haven’t done any welding in years and that was with a stick welder…. would I have to drain the tank as I would hate to waste all that water?
    Would one of those cheap migs from haborfreight using flux core do the job or would I be better off using one of their cheap ac/dc arc welders?
    Jul 2005
    You stand a good chance of blasting a big hole if you try arc welding. The tank is probably rusted thin all over and just happens to have penetrated in a couple of areas.
    I would soft solder or silver solder a patch on the outside but the tank will have to be emptied below the hole level.
    Dec 2006
    Patching Hole
    Depending on the temperature, perhaps this method will work. I have seen leaking power transformers patched without draining by puilling a vacuum on the tank and then sealing the hole with one of the catalized patching materials. I also have patched an oil cooler radiator on a large air compressor with this method.
    OM
    Dec 2005
    Look into quick reacting epoxy. I"ve seen it for use on fuel tanks and they even have stuff that mixes under water.
    Unless you can get the water below the hole, welding is out if the question - liqufied steel and water do NOT like each other AT ALL!!!!
    Jul 2005
    Combine the above two suggestions; pull a vacuum on the tank and slap on a little bit of the water proof epoxy. Keep the extra epoxy so you can repeat the process on other leaks as they arise...which they will with an old tank that has started leaking.
    Nov 2006
    australia
    If the metal is not to thin maby you can push some soap or putty into the hole from the inside just to stop the flow of water and then weld your patch on, the water should keep the soap and putty cool enough so it doesnt fall out while welding, stick tig or mig should be better as the heat sink for oxy may be to much.With a bit of luck there will be no cracking,im assuming the holes are at the bottom of the tank ,good luck regards greg.
    Jul 2007
    thanks all... I had a professional come in a work on it and he welded it with a mig after we drained it as the pin hole was on the bottom of the tank…
    1. Stainless Steel Sheet Welding ??
      By twocik in forum Welding, Brazing, Soldering, Sealing
      Last Post: 09-27-2007, 04:59 AM
    2. welding 1/4 in steel
      By mik32176 in forum Welding, Brazing, Soldering, Sealing
      Last Post: 02-03-2007, 12:21 AM
    3. TIG welding stainless steel
      By owhite in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 10-24-2005, 09:39 PM
    4. Looking for Helical Cut Carbon Steel Gears
      By b0gh0s in forum Employment Opportunity
      Last Post: 08-18-2005, 04:46 PM
    5. Stainless steel forge welding
      By brickman in forum Bending, Forging,Extrusion...
      Last Post: 08-05-2004, 01:17 AM
