Results 1 to 7 of 7
Thread: Welding a tapered pipe
    Nov 2005
    Hello all,
    I am trying to clamp together a piece of flat steel that has been rolled. The steel gets within about 4" of being closed, so I must close the gap and then weld the seam. Does anyone have any recommendations on the best way to clamp a varying diameter tube?
    Gold Member mxtras's Avatar
    May 2005
    How thick is the wall? Could you use hose clamps?
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Nov 2005
    well i think i now have a killer idea. however, i defiantly would like to hear other ideas. Hose clamps are out simply because of the shear size of some of the tubes that will be used ( i think the max is like 30" diameter). i think wall thickness can range from like 18Ga to prolly 3-6mm
    Registered Kool Parts's Avatar
    Jan 2004
    Easy...rope around tube...twist to tighten. Use a broom stick to twist with, then you can wedge it on the floor, or foot to hold while you tack...with both hands free
    Jul 2005
    Quote Originally Posted by sleepy23 View Post
    Hello all,
    Make some tabs with holes. Weld these tabs on both sides, back a little bit from the edge. Put a length of threaded rod through the holes and run nuts in from both sides until the edges are at welding distance. Tack the joint in several locations, remove the threaded rod, grind the tab welds and break them off, finish the seam weld.
    The size of the tabs and threaded rod has to be chosen to match the material thicknesss.
    Registered 300sniper's Avatar
    Jul 2007
    ratchet straps would be quick and easy. depending on the thickness of the material being worked with you could use small motorcycle type straps or larger heavy duty ratchet straps.
    Jun 2005
    Another aspect will need some consideration is the welding.
    Depending on the length of the tube.
    You will need to tack weld at frequent intervals and I would suggest a back stitch sequence to minimise distortion.
    Just a couple of cents worth.
    The More I Learn The Less I Seem To Know
    1. tapered hole
      By dshowald in forum Milltronics
      Last Post: 05-01-2007, 12:19 PM
    2. Tapered gib
      By chevdrgtrk in forum General Metal Working Machines
      Last Post: 11-28-2006, 02:56 AM
    3. Tapered Bore?
      By dwarf66 in forum General Metalwork Discussion
      Last Post: 11-23-2006, 03:56 PM
    4. emt conduit, galvanized pipe or black pipe?
      By JohnG in forum DIY CNC Router Table Machines
      Last Post: 05-21-2006, 09:24 PM
    5. Setting up a tapered cutter
      By cybeeria in forum General Metalwork Discussion
      Last Post: 03-20-2006, 09:16 PM
