Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Welder
    Gold Member Mr.Chips's Avatar
    Sep 2003
    USA Tucson AZ
    Question Welder
    What is the thickness that the below welder would be most suitable for?
    And what is the maximum thinkness that could be welded with it.
    http://www.harborfreight.com/cpi/cta...unction=Search
    hager
    Registered Weldtutor's Avatar
    Oct 2005
    Link works, but says item number is not valid.
    Sep 2003
    USA Tucson AZ
    Question
    Quote Originally Posted by Weldtutor View Post
    Sorry the item number is 44567.
    90 amp flux wire welder 115 volts uses .030" fluxed-core wire.
    Hager
    Oct 2005
    Quote Originally Posted by Mr.Chips View Post
    The PDF manual shows a range of 16 ga. steel to 1/8" so,
    pushing to the maximum would be the 1/8"
    Sep 2003
    USA Tucson AZ
    Smile
    Sounds like it would be good for sheet metal but not for anything over 1/8"
    Not a very useful general use welder for the occasional hobby welder which would run into 1/4" once in a while.
    What is the minimum AMP or however it is measured to weld 1/4"
    Hager
    Registered Aksess's Avatar
    May 2004
    It can weld 1/8-3/16 but the duty cycle is the killer only 10% @ 80 amp you would only get to weld around 6 seconds per minute. If tacking is all you will be doing with it then it will be fine, But for any real fabricating I would advise to steer clear of it and look for a higher duty cycle.
    Most larger welders will have a 60% - 100% duty cycle.
    Nov 2006
    australia
    you will probably need somewhere near 150amp+ to put a reasonably hot weld in greg b
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    175 Amp.
    www.integratedmechanical.ca
    Gold Member
    Nov 2005
    Mr. Chips: Try Pima Welding Supply ( one is on Park Ave, South Tucson and one is on Prince Ave near I 10) They sell the Miller 175 MIG at a very resonable price..I have had mine for 5 years, it welds excellent,low maintenence, very good machine to learn on.It is smooth enough to "stack Dimes" with out a big learning curve. The 110 models are really marginal for anything other than thin sheet metal.And as far as I'm concerned can be dangerous do to lack of penetration.
    Flux wire is ok for welding outside in a windy condition ( the Miller will also use flux cored wire, if necessary) but using the .025 or .035 wire with mixed gas really makes a better, safer weld..
    Adobe (old as dirt )
    Sep 2003
    USA Tucson AZ
    Quote Originally Posted by Adobe Machine View Post
    Thanks Adobe
    This is the information I needed. It has been in the back of my mind for some time and is a very useful tool. And we always need one more tool.
    Hager
    Gold Member
    Nov 2005
    I also have note books full of "Gotta Have " reasons for the significant other if needed !
    Adobe (old as dirt)
    Aug 2005
    If you have a TSC near you and have 220 service, I would suggest a Hobart Handler 187. TSC had a sale on them for $549 plus tax a while ago but we talked to one of the managers over the past weekend and they still honored the price. It's a smoking deal for a welder very similiar to a MM 180. 0.023" wire with C25 gas will give great results on sheet metal. They were also about half the price of the local gas supplier when it came to refilling gas cylinders.
    Josh
  • Page 1 of 2 12 LastLast
    1. My Homemade TIG welder
      By js530 in forum Welding Brazing Soldering Sealing
      Last Post: 04-03-2013, 07:52 PM
    2. I'm ready to buy a tig welder, now what?
      By mik32176 in forum Welding Brazing Soldering Sealing
      Last Post: 10-07-2010, 07:54 AM
    3. ready welder II?
      By fyffe555 in forum Welding Brazing Soldering Sealing
      Last Post: 12-05-2006, 11:47 AM
    4. Need help with new welder : Lincoln TIG 300
      By delangecycles in forum Welding Brazing Soldering Sealing
      Last Post: 04-07-2006, 10:43 AM
    5. Homebrew welder
      By DSL PWR in forum Welding Brazing Soldering Sealing
      Last Post: 01-05-2006, 12:51 AM
