Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Welding, Brazing, Soldering, Sealing
Welding, Brazing, Soldering, Sealing Discuss Welding, Brazing, Soldering, Sealing technique's here.
Old 11-25-2006, 05:04 PM
zcases's Avatar
zcases is on a distinguished road
Tig filler "handle"
I can't remember where I saw these tig filler "handles". My searches have come up empty handed. Anyone know what I'm talking about? Its like a mechanical pencil type thing, and you can push a button or something to feed the filler a little bit at a time, keeping your filler hand in a relatively stable position..............
Scott
Old 11-25-2006, 05:46 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
Yes I have used one of those a long time ago, They were a pain in the back side compared to the full automatic tig.
Old 11-25-2006, 06:12 PM
zcases's Avatar
Gary, you mean like a cold wire feed? I want something to help with tigging with some small .020, .030, .040-ish wire, by hand.
Old 11-25-2006, 06:48 PM
GaryCorlew's Avatar
yes that is what I am talking about. After those we got some that had the wire feed tube attached to the tig torch, it could be swiveled around to any position so the feed could be in front of the direction of travel. These could pulse the wire or continous feed and also you could pulse the arc set delay arc on and off time. I dont think it would be that difficult to make a hand held feed. If that is what your looking to do.
Old 11-25-2006, 07:12 PM
jpgdesigns is on a distinguished road
Check this link.
http://www.ckworldwide.com/coldwire_hand.htm
or this manual one:
http://www.awisco.com/tigpen.html
JPG
Old 11-25-2006, 07:17 PM
GaryCorlew's Avatar
Yes there is that pia right at the top!!, We went to the ones that are listed in the top of the water cooled section(much better!!)
Old 11-25-2006, 09:01 PM
zcases's Avatar
Pretty interesting....looks expensive. What kind of ballpark on the water cooled setups?
[IMG] code is Off
