Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Welding, Brazing, Soldering, Sealing
Welding, Brazing, Soldering, Sealing Discuss Welding, Brazing, Soldering, Sealing technique's here.
Old 10-16-2006, 11:12 AM
neonguy is on a distinguished road
auto-darkening helmets
I am thinking about purchasing an auto-darkening helmet, I was wondering if the “cheap” helmets are any good? I understand you get a smaller viewing area and the “cheaper” helmets don’t perform as well as the name brand helmets. I don’t weld a lot, but I wanted to try one out.
I guess I want to know if anyone out there is using a “cheap” helmet and if so what they think of it?
Marc Harmon
Old 10-16-2006, 12:55 PM
Marc Harmon
What value do you put on good eyesight?
Cheap ones work but not as reliably as higher priced ones. Having the helmet turn off because the arc has been shadowed by part of the job is disconcerting to say the least. Our cheap auto darkening helmets stay hung up and the expensive ones are used now.
Old 10-16-2006, 06:33 PM
krt9751 is on a distinguished road
i use the cheap one weld about 10hours a week no problem i like it. the cheap one you are talking about you mean the ones at harbor freight
Old 10-16-2006, 06:49 PM
Ya... I was looking at the 49.99 (ITEM 91214-1VGA) one that is battery powered; I don't have the best lighting and was worried about the solar powered one.
Thanks for the input
Marc
Old 10-16-2006, 06:53 PM
snowshovelbmx is on a distinguished road
If you do not do a lot of welding then your best bet would be to stick with the non-auto helmet, the effort it takes to put the helmet up when not welding and down when welding is worth not getting flash by using a cheap helmet. Also, This may not be a problem, but depending on the type of welding you are doing the cheap helmet may not be dark enough as most are only an 11 sometimes when welding stainless or while doing long welds your eyes still hurt afterwards. As Geof said if the helmets sensor is blocked by a bar, arm, or anything else that makes a shadow and it cannot "see" the weld then the helmet will not darken right away.
As a side note, the helmets solar power mostly comes from the light generated from welding, but if you do not use it very often the battery powered version may be better, as long as you always have fresh batteries.
Old 10-17-2006, 07:50 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Exactly
The solar battery gets it power from welding not ambient light.
The cheap ones work fine but IMO your helmet should be conditional on the work you do.
Welding laying under a car you need an auto helmet because there is no room to "flip" a regular helmet.
For TIG weldin you will need an expensive auto helmet, the cheap ones are not sensitive enough and will flash off and on during welding.
If you do a lot of MIG welding (hours per day) you will likely want a good helmet or add an extra 3X plate in front of the auto helmet IMO most auto's do not go dark enough and after a day of MIGing your eyes will hurt.
On another note I REALLY like the "OMNI" lense for welding clarity and Auto darks are green only, so I use the old Tiger hood most of the time.
www.integratedmechanical.ca
Old 10-20-2006, 02:56 PM
handlewanker is on a distinguished road
Hi all, I've just started "improving" my stick welder by converting it to tig capability, and one of the extras I've outlaid for is an auto darkening helmet. I bid for it on EBAY and got it. Just worried about the arc capacity when doing tig to keep the shades dark etc. as you have mentioned.
I'll keep you informed as I'll try it out at a mate's workshop where he's a full time welder.
The supplier is Oregon Tools and the model type is an ANSI.
Ian.
Old 10-20-2006, 03:43 PM
Kipper's Avatar
Kipper is on a distinguished road
I have an Autoglas helmet...Expensive :yes: and at work there is also a "cheap" one...Nobody can use a cheap one once they try a good one...But they cant use mine as i'll get angry as they dont respect the value of such things. I never put mine on any surface without a soft covering to prevent scratches which is probably why my 12yo helmet is in better condition than the firms 12month old one.
Keith
Old 10-22-2006, 09:05 AM
swartling is on a distinguished road
More on helmets
I use an OPTREL SATELLITE OSE at work. www.optrel.com I like it alot. I do alot of mig & tig welding with it. What does everyone think of these helmets?
Also I have been interested in the Miller Elite Series helmets. Anyone have comments on these helmets as well. I am also looking for a place that has a good price on them. I don't care where it is. I like the larger vewing area they have and the controls are on the inside of the helmet not like the Optrel.
Brian
Old 10-25-2006, 02:49 PM
*Registered User*
JB Fab is on a distinguished road
I used to use an optrel sattelite at work, I liked it. I own my own Jackson Nexgen, I love that hood. I wouldn't trade it for any other, not only for the quality, but also the customer service.
  #11   Ban this user!
Old 10-26-2006, 03:24 PM
3faze is on a distinguished road
IN my opinion the speedglass (now owned by 3M) 9002x is the ultimate helment on the market, the viewing clarity is unbelievable, I highly recomend you at least try this helment. Brandon
  #12   Ban this user!
Old 10-29-2006, 02:53 AM
Hi, just to relate a funny incident on the way to the forum. When the auto darkening lens helmets first came onto the market, a number of mates I used to meet with played a joke on one of the welders at their workplace.
They took a standard flip up helmet and had it spray painted a bright yellow. Then they told the welder that it was the latest auto lens model and he could give it a try.
He looked at the lens and commented that it was dark. No problem, they said, it's a solar type, and as soon as the arc strikes you can see through it.
He gave it a go and came back 10 mins later, big smile. "work great", "'ow much you want it for?" He's Greek.
Well after negotiating a price of A$50, because it was a sample model, (cost A$24 new), and a slab of beer, they left him to it.
Only problem was the boss got to hear about it and decided to give it a go, he loved it too and wanted one so the welder gave it to him for A$75 and a slab of beer.
Long story short, the story eventually got out due to the "lens" getting broke and as the replacement wasn't available a normal welding shade glass was fitted. The money was returned to both parties, but the beer was all gone and so it died a quiet death.
Last time I heard of the "helmet" was, it was hanging from a rafter by a bit of string, as a warning to all jokers.
Ian.
[IMG] code is Off
