| Welding, Brazing, Soldering, Sealing Discuss Welding, Brazing, Soldering, Sealing technique's here. |
Just wanted some help with the conversion. The welder is a Miller Thunderbolt XL 225/150 Amp. I have an air cooled TIG torch, gas and regulator. Am I correct to assume that I will need a high-frequency unit and a foot or thumb control to start TIG welding? Any info would be greatly appreciated. Thanks |
| It has been a while since I tried the same thing, but what I found/was told was that even though this is possible, the only way you could control amperage was on the face of the arc welder. It works on the same principles as GTAW, but of course needs the shielding gas etc. I may be mistaken about converting to adjustable amperage, but that is what I found. Sorry I couldn't be more help
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) "If the women don't find you handsome, they should at least find you handy" -RedGreen show. |
| I assume you will have the same problem with converting stick welder to TIG as you would MIG, the characteristics of the transformer and supply is quite different. With Stick welder the transformer attempts to supply constant current source as opposed to MIG which is a constant voltage source at a somewhat lower voltage. The stick welder is higher open circuit voltage which would be no good if this voltage was sustained at the rated current of the welder, therefore in a stick welder, the secondary of the transformer is usually loosly coupled and has a shunt to control the resulting voltage/current. i.e. the voltage starts to collapse as soon as a high current demand is required. I am not sure what the open circuit requirement of TIG is, Stick welder is typically 70v open circuit and MIG is around 35v. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Nice explanation js, I believe that the machine meets the minumum voltage you said for argon. So your saying that all I need is a footpedal/torch control? I am not familiar with phase angle contriol via triac but I will check it out. Thanks. |
