Results 1 to 2 of 2
Thread: Silver brazing porosity issues.
    Aug 2010
    U.S.A.
    I have attached a sketch of a part I silver braze together.
    Both componenents are 303 SS. They simply press fit together so there is no capillary action going on in the area of the press fit.
    I heat and add silver braze to the chamfer area. Once the part is cooled and flux is removed I have to file and sand the top surface so it is completely flat.
    I must be doing something wrong sporadically because about 25% of the time when I file the silver braze there can be porosity showing which is not permitted. The area being filled is relatively large. I say that with the belief that the intention of silver brazing is usually capillary in nature. I don't think the intentioon of silver brazing is to put a bunch on and then file a bunch of it away.
    Being the porosity does not happen consistently it makes me wonder if I'm boiling the silver braze filler ( trapped bubbles). I do my darndest to apply minimal heat and even take a piece of pointed tungsten and stir around the chamfer to try and free any bubbles.
    I'm wondering if porosity in a joint that large is typical.
    I'm using StaySilv 45% with white paste flux.
    I have used oxy-acetylene , acetylene-air and propane-air.
    I prefer the propane or air-acetylene because it helps prevent overheating of the part.
    Any help would be appreciated. I have 400 of them to do and would like to hit it the first time around.
    And no, I am not permitted to use a different method to construct or join the part together.
    Randy
    Attached Thumbnails Attached Thumbnails Silver brazing porosity issues.-1203071434_001.pdf
    Aug 2010
    U.S.A.
    I tried to open the attachment and was not successful. If you can't either here is a description of the joint.
    It is a 3/16 diameter shaft with a 1/32 x 45 degree chamfer that is pressed into a 1/4'' thick tab with a 3/16 diameter hole in it. The hole has a 1/32 chamfer that when the two parts are pressed together form a vee groove that will be filled with silver braze.
    Randy
  1. HTS-735-II brazing rod?
    By jeffmorris in forum Welding, Brazing, Soldering, Sealing
    Last Post: 02-01-2012, 12:25 AM
  2. Brazing or soldering?
    By Captdave in forum Welding, Brazing, Soldering, Sealing
    Last Post: 09-06-2010, 11:21 AM
  3. Need Help!- Brazing...........????
    By Taylorm in forum Welding, Brazing, Soldering, Sealing
    Last Post: 03-31-2009, 02:28 AM
  4. brazing Aluminum help
    By skipper in forum Welding, Brazing, Soldering, Sealing
    Last Post: 03-03-2008, 07:19 PM
  5. silver brazing
    By owhite in forum Welding, Brazing, Soldering, Sealing
    Last Post: 02-13-2004, 07:41 PM
