| Welding, Brazing, Soldering, Sealing Discuss Welding, Brazing, Soldering, Sealing technique's here. |
| weld chrome moly First thanks for the help on narrowing my 12 bolt rear axle. It came out strong and straight. Now I need to fab a wishbone track locator to keep my rear end centered within the frame rails. The cheap one is .156 wall DOM that I can weld up with my MIG. The better one is chrome moly tube with 4130 tube inserts. My question is can I weld chrome moly with a Lincoln SP-135? |
| its been my experience that if your making 4130 welded then you weld with standard (es-70) rod if you are NOT heat treating after welding. If your heat treating I believe you use stainless rod (300series but thats a stretch on the old brain cells cause its been a few years) then heat treat. and yes a mig can weld it.
__________________ thanks Michael T. "If you don't stand for something, chances are, you'll fall for anything!" |
| Check out this it might help http://www.lincolnelectric.com/knowl...hrome-moly.asp http://www.eng-tips.com/search.cfm?a...uesttimeout=75 |
| Be very carful welding 4140 ,after it cools the weld is very brittle .
__________________ Tim |
| WeCheat, Nice link, the only thing I would add is preheat. It isn't mandatory but, Its always good to pre and post heat any steel with chrome. Gary |
| Goofour, how bout a little info on your project as there are plenty of us car nuts at this forum. (not only the rear end but the car too) |
| I started with a 1976 Triunph Spitfire. So far it has a new 4x2x1/8 tube frame, 12 bolt rear end out of a 3/4 ton pickup narrowed to 32". 29x15x15 Houser drag radial rear tires, 16 gal fuel cell and two battery boxes that all fit neatly into that little trunk. After I finish the track locator I will be working on using S10 pickup spindles and disc brakes in the front. 350 ci small block and a four speed automatic plus a six point cage. Its a lot of work but it should be a hell of a car when its finished. |
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452 |
| Goofour: Great project, one mean car and nice work. Thanks for sharing. |
#10
| I could swear I posted on this topic earlier - I guess I am loosing my mind.... Preheat, weld and then wrap with welding blankets to cool as slowly as possible - this is what I was taught. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
#11
| Thanks guy's now I have a plan |
