Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Welding, Brazing, Soldering, Sealing
Welding, Brazing, Soldering, Sealing Discuss Welding, Brazing, Soldering, Sealing technique's here.
Old 09-27-2005, 05:42 PM
Chris D's Avatar
Chris D is on a distinguished road
Bonding flanges to a timing pulley?
Hi All,
I am making some timing belt pulleys for my spindle drive on a small machine. I have to add flanges to one of the two pulleys or the belt will surely walk off the pulley.
The flanges will be approximate sizes...
ID 3.75
OD 4.25
Thickness .050"
I originally was thinking of having a friend tack weld these one but my gut is telling me they will warp like the dickens. So, I am wondering if there are some epoxies that could be used to bond these flanges onto the pulleys?
I was thinking perhaps J-B Weld would work as that is a really tough, metalized epoxy that seems to bond well to metals. Anyone ever tried this?
TIA
Chris
Old 09-29-2005, 07:08 PM
MrHorsepower is on a distinguished road
Any good tig welder should be able to do this. Hell send them to me I'll take care of it if you like.-Dave
Old 09-29-2005, 11:30 PM
ViperTX is on a distinguished road
Okay...I'm a bit confused....why would the timing belt walk off the timing pulley....that should only occur is there is misalignment......just wondering??
Old 09-30-2005, 08:08 AM
Chris D's Avatar
For the same reason the belt mfgs. recommend it - because it can happen. They recommend at least one of the two pulleys be flanged.
Old 09-30-2005, 08:31 AM
bdrmachine is on a distinguished road
Gist I thought, I've seen timing belts with a center rib. No flanges needed. One brand name is Flex-E-Grip. You would have the added task of cutting a radius groove around the circumference of your pulleys.
Hope this helps
Old 09-30-2005, 08:48 AM
Chris D's Avatar
Hope this helps
Thanks, will check into that. It sure would beat putting on these darn flanges!
CHris
Old 09-30-2005, 09:27 AM
Chris D's Avatar
Thanks for the offer Dave, I do know a couple of welders so I will check into that option too.
Chris
Old 10-01-2005, 08:45 AM
Unabiker is on a distinguished road
If I were going to glue a part like that together, I would use some Hysol epoxy. We used a few different flavors to do repair work on Indycars, and it is pretty amazing stuff.
Makes JB weld look like scotch tape.
Google Loctite and Hysol.
Old 10-01-2005, 09:37 AM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
Flange on pulley
Here's one that uses screws...then the "ring" flange is slightly stamped(peened) between the screw spacing for added security.
Name:	Flange on pulley.JPG‎
[IMG] code is Off
