Results 1 to 4 of 4
Thread: How to re-condition welding leathers
    Jan 2006
    I have some old welding leathers that seem to be a split-hide or suede type of leather that are getting a little bit stiff from age.
    What is the best thing to use to re-soften the leather?
    Thanks.
    Jan 2011
    Anything I can think of will make the leather easier to light on fire. Wouldn't want to go there myself
    Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
    Jul 2011
    Sometimes I will powerwash mine at the carwash, which makes them stiff, so I throw them in the dryer (while my wife's not home!) and let them tumble.
    Oct 2005
    Leather gets hard when it drys out. You can add moisture by itself but it dries out fairly rapidly.
    The trick is to use some sealing compound (dubbin, wax type boot polish etc) and some moisture. Get the leather a bit damp first then a small amount of boot wax to seal the moisture in. I think if you go sparingly on the boot wax it should not be a fire hazard.
  1. Newbie- is this welding lens right for the job ? (stick welding)
    By cnc2 in forum Welding, Brazing, Soldering, Sealing
    Last Post: 07-05-2011, 07:19 PM
  2. Problem- Tailstock condition
    By littlerob in forum Okuma
    Last Post: 09-23-2009, 07:53 PM
  3. TIG welding Steel/Iron welding with Argon?
    By Rich05 in forum Welding, Brazing, Soldering, Sealing
    Last Post: 12-01-2007, 08:11 PM
  4. If condition
    By mr_electrician in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 06-09-2007, 11:44 AM
  5. Cutting condition.... please !!!!
    By speedhawks in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 11-08-2005, 03:31 AM
