Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Welding, Brazing, Soldering, Sealing
Welding, Brazing, Soldering, Sealing Discuss Welding, Brazing, Soldering, Sealing technique's here.
Old 08-18-2005, 02:20 PM
damae's Avatar
damae is on a distinguished road
Lincoln 3200 HD - a good buy?
A friend is offering to let me use his welder if I repair the gun, which has something wrong with it. I'm loooking to buy it from him outright, since he doesn't use it anymore.
Is this a good welder for putting together a steel tube frame with 1/4" walls? Anything I should watch out for since it's used?
Thanks!
-D
Old 08-18-2005, 02:23 PM
ViperTX is on a distinguished road
The gun only has a liner, a tip and a switch....heck I would use.
Old 08-18-2005, 02:59 PM
damae's Avatar
Hmm. Maybe it will be easier to fix than I thought. He probably just got the tip shorted or something. Thanks!
[IMG] code is Off
