| Welding, Brazing, Soldering, Sealing Discuss Welding, Brazing, Soldering, Sealing technique's here. |
| Hairbrained Idea? I have a little Sears 105 Amp MIG machine and it does wonders on steel. It says 20% duty cycle but I 've used it for hours at near capacity amps at 75%. Anyway I tried some aluminum wire and it does feed okay but trying to get an arc on even thin material is a joke. The wire just welds to the base metal. I can't afford a real TIG machine right now. Now comes the hairbrained idea. I have a 225 amp AC stick machine. Can I disconnect the MIG machine electrodes from the unit and feed the stick macine output to the MIG torch? What would be the result? Would I have a better shot at welding some aluminum? I'd have twice the amps, ac which is better for aluminum, yes? And an Argon shield. Jerry |
| I have a lincoln sp100 I use to weld aluminum just fine with. The secret is change the liner, go with the smallest aluminum wire you can find .022 I think is what I use, and pure argon gass. |
| In general, it wouldn't work,,, Mig machine power supplies are a constant voltage supply, with varying amperage depending on wire size, wire speed, and the distance between your work and the contact tip. Stick machines are a constant amperage, variable voltage. There are wire feeders that can be hooked up to a stick machine,,,, but they have built in a wire feed speed control that tries to maintain a set voltage by varying the speed of the wire feed. |
| use a aluminum rod for the stick machine? if the weld doesn't have to be pretty you can get a good weld with an ac stick machine with practice. that's what i had to do till i got the syncrowave 350 |
| EDM idea | DragnsBane | CNC Plasma and Waterjet Machines | 5 | 02-23-2005 06:50 AM |
| I'm still new to this and so is this machine idea? | toad32 | DIY-CNC Router Table Machines | 3 | 12-24-2004 02:41 AM |
| Idea for machine | SPEEDRE | 80/20, TSLOTS and other Aluminum Framing Systems | 0 | 11-13-2004 01:01 PM |
| new project idea | newguy | DIY-CNC Router Table Machines | 19 | 10-24-2004 09:47 PM |
| New idea! | smitty | OneCNC | 3 | 08-26-2003 11:45 AM |
