Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: NEwbie Help, is this too thick for my TIG ?
    Feb 2005
    Indonesia
    I just learn/start welding using this TIG, my TIG dosn;t have High Frequency.
    the result is ... the tungsten was "eaten" fast, every touch I start it just eat the tungsten wire.
    I know my skill is zero, but I think something wrong with my TIG, I think it's too small to weld the 6mm thick.
    is it ?
    see the attachment pleae
    and help
    I got this huge project waiting.
    all info is in the photo, sorry my cellular photo quality just like my welding skill.
    rud
    Attached Thumbnails Attached Thumbnails NEwbie Help, is this too thick for my TIG ?-image_00017.jpg   NEwbie Help, is this too thick for my TIG ?-image_00018.jpg   NEwbie Help, is this too thick for my TIG ?-image_00019.jpg   NEwbie Help, is this too thick for my TIG ?-image_00020.jpg
    NEwbie Help, is this too thick for my TIG ?-image_00021.jpg   NEwbie Help, is this too thick for my TIG ?-image_00022.jpg
    Feb 2005
    Indonesia
    oopsss that's my material I'm going to weld, sorry.
    here we go
    Attached Thumbnails Attached Thumbnails NEwbie Help, is this too thick for my TIG ?-image_00034.jpg   NEwbie Help, is this too thick for my TIG ?-image_00035.jpg   NEwbie Help, is this too thick for my TIG ?-image_00036.jpg   NEwbie Help, is this too thick for my TIG ?-image_00037.jpg
    NEwbie Help, is this too thick for my TIG ?-image_00038.jpg   NEwbie Help, is this too thick for my TIG ?-image_00039.jpg
    Feb 2005
    Indonesia
    more
    and help please ...
    ruddy
    Attached Thumbnails Attached Thumbnails NEwbie Help, is this too thick for my TIG ?-image_00040.jpg   NEwbie Help, is this too thick for my TIG ?-image_00044.jpg   NEwbie Help, is this too thick for my TIG ?-image_00045.jpg   NEwbie Help, is this too thick for my TIG ?-image_00046.jpg
    NEwbie Help, is this too thick for my TIG ?-image_00047.jpg   NEwbie Help, is this too thick for my TIG ?-image_00048.jpg
    Registered Kool Parts's Avatar
    Jan 2004
    Ahhh, where to start.
    By the sound of it you may have the leads hooked up wrong. The power lead to the tig torch should come from the negative -- side of the welder
    Also maybe oxygen contamination in your argon flow. Push the tungsten in all the way and seal the end of the cup with your finger, The ball in the flow meter should fall to 0. If it doesn't you have a leak somewhere. And I would agree that that welder is on the small side for your skill level and the looks of your project. I would suggest a smaller project to learn on.
    Gary
    Apr 2003
    USA ofallon, Mo
    You will need to set it up using (AC )with High Frequency for alum.
    (-DC) NO HF For steel
    Feb 2005
    Indonesia
    wow wait a second,
    my torch is connected to Positif and the negative connected to the material I weld.
    correct ? thisis what the seller said to me.
    Oct 2004
    you connect the torch to negative and the work to the positive check out miller welds. if you look in the tech section you can download their tig hand book. i am just learning my self so i know where you are at
    Feb 2005
    Indonesia
    ok I got it HF for alum.
    steel no need HF.
    thanks
    what about the polarity, did I connect it wrong ?
    rud
    Jan 2004
    First off the material shown is steel, not alum. So there is no need for AC.
    Second, for steel tig, the leads have to be DC- for the tig torch. DC+ for the ground.
    Third you dont have HF but if you did you would use it for steel and stainless, but just to start the arc, that way you dont contaminate the tungsten.
    Gary
    Feb 2005
    Indonesia
    my god, I'm so wrong about polarity.
    how much argon flow aprroximately if I weld steel ?
    ok my newbie question,
    if I use welding for steel without argon, just a stick attach to the torch, do I need AC or DC ?
    if it's DC the torch is connected to positif right ?
    regards
    ruddy
    Jan 2004
    Calico,
    Here are a coulple of links that will really help out.
    http://www.millerwelds.com/pdf/PrinciplesSMAW.pdf
    http://www.millerwelds.com/education/TIGhandbook/
    Gary
    Feb 2005
    Indonesia
    now that's what I want...
    very usefull.
    thank you.
    is there any video doing TIG welding ?
    close up to the welding it self ?
    rud
  • Page 1 of 2 12 LastLast
    1. Newbie - To build or not to build Router/Plasma Table
      By dfranks in forum General Waterjet
      Last Post: 04-08-2011, 12:16 AM
    2. 90Amp Arc / TIG Conversion
      By barkster in forum Welding, Brazing, Soldering, Sealing
      Last Post: 11-23-2006, 12:11 PM
    3. Questions about TIG
      By jrc347 in forum Welding, Brazing, Soldering, Sealing
      Last Post: 11-10-2006, 10:40 PM
    4. Replies: 11
      Last Post: 03-13-2006, 09:23 AM
    5. How thick is too thick?
      By lookalion in forum General Metal Working Machines
      Last Post: 08-30-2004, 03:08 AM
