Results 1 to 10 of 10
Thread: Linde UCC 305 TIG not working
    Jan 2010
    I just bought a Linde UCC 305 stick/TIG welder. Massive machine. Industrial. When I fired up the welder the TIG portion didn't work. I'm looking for someone who might have the wiring diagram.
    If not the wiring diagram, suggestions on where to start looking for the problem. Very confusing.
    Also, when in "stick mode" there is a strange buzzing sound. Like arcing. Not the sound of relay hum. Very curious.
    Any assistance is greatly appreciated.
    Sep 2003
    chester,england.uk
    Did you manage to find a wiring diagram? I'm having exactly the same problem with my 305.
    Jan 2011
    I dont know about a Linde but my old Airco has High Freqency for tig there is a switch that say start off continus for the hf when it is on you here the buzz sound does it have a foot pedal control?
    Not much help I know but its like money any is better than none
    Mike
    Oct 2011
    Here is one place to start. From an earlier post:
    Re: AIRCO HELIWELDER V TIG problems
    A high percentage of the time in our business the complaint of low hi freq. goes back to the machine having a welding lead attached even when Tig welding. The situation is aggravated if the welding lead is coiled and lying against metal, say the side of machine. An easy fix is to add female terminal to output and male on welding lead so that the lead is attached only when stick welding. If hi freq. is not restarting arc in the condition you describe, foot control is one likely culprit. The earlier Airco Heliwelder series that are obviously not Miller were built by Midstates with some being carried over to Esab. In any case you can still get some parts and information from Arc Products @ 800-770-0063 in San Diego. weldersales
    Even coiling the torch lead itself can choke the high freq. quite a bit, especially if the coils are close to metal. Keep in mind your machine has a rheostat to adjust somewhat the amount of high freq. available. Weldersales
    Oct 2011
    Quote Originally Posted by jdanger2001 View Post
    Hi. If you're still interested let me know and I'll check and I'll send it to you. I'm pretty sure I've got one.
    Jessie
    jh53@cox.net
    Oct 2011
    UCC wiring diagram/users manual
    Hi.
    I was just contacted tonight from a guy who needed the manual for the ucc305. I just uploaded it. If you can't receive it please let me know by email jh53@cox.net and I will send it to you. I also have the original wiring diagram and if you want that also please let me know as I have to scan it and post/send it to you. The following is from my earlier post.
    Attached Files Attached Files
    Oct 2011
    Most any machine has either a foot pedal control or a manual control. If yours is making a buzz sound most likely the hf is working. You should have a switch that says remote for a foot pedal connection. From what I see, though not guarenteed, many foot pedals are universal. I see some on Ebay.
    Good luck
    Jessie
    Oct 2011
    Yes I have the "original" wiring diagram for this machine. If you are interested in it please drop me a line and I will scan and send it to you. You will also notice that I have uploaded the manual for this machine. My email address is jh53@cox.net.
    Good luck.
    Jessie
    Oct 2011
    I hope you got the manual I sent you. If you want the wiring diagram please let me know. There appears to be little that can go wrong with this machine. Most of it is in the interefrence caused by the crossing of the cables. The only other thing that I've found that goes bad is the rheostat in the foot pedal control, but those are readily available.
    Good luck
    Jessie
    Dec 2011
    Send an Email to Stan Smith (ssmith@esab.com) He has been one of ESAB's lead techs for years in the customer support group. I am sure he would be happy to help.
    1. usb to db-25 not working
      By fusiontech357 in forum General Electronics Discussion
      Last Post: 11-08-2009, 01:51 PM
    2. Linde CM-40 oxy-fuel shape cutter
      By gtwitty in forum General Waterjet
      Last Post: 05-17-2009, 06:16 AM
    3. help!!! Linde CM-50 Shape Cutting Machine
      By csteelart in forum General Waterjet
      Last Post: 11-11-2008, 10:49 PM
    4. Linde CM-50
      By theweldor in forum Shopmaster/Shoptask
      Last Post: 02-20-2008, 08:56 AM
    5. Linde CM-56
      By JohnnyGalto in forum General Waterjet
      Last Post: 03-28-2007, 10:04 PM
