- Need Help!- 1095 spring steel welding
Hello welders
I need your help!!! I want to make brackets which will have 1095 spring steel 0.032" thick sandwich between two pieces of .125" thick cold rolled steel. What is the best way to join all 3 together? Drill holes in brackets and make a fill weld. Or maybe spot welding? Can I even weld 1095 spring steel?
- You may not post replies
- You may not edit your posts
Forum Rules
