- Welding caused bend. How to straighten the square tube?
I welded some 40x40x4mm iron tubes. The tube is 1 meter long. I've been very careful not to bend it got bent anyway. Now I need to straighten it. What is the best way for this? Heat, hit with an axe, jumping on it?
Thanks.
Re: Welding caused bend. How to straighten the square tube?
heat the side thats curved outward. The shrink of the heat will pull it back.
So if you made a T-joint, heat the side without the welds.
I have always welded one side a bit then the other an so on so the heat is the same both sides I was a coded welder years ago last job was on channel tunnel
- You may not post replies
- You may not edit your posts
Forum Rules
