Problem Welding Cymbals
Results 1 to 4 of 4
Thread: Welding Cymbals
    Jan 2013
    United States of America
    Default Welding Cymbals
    Aug 2006
    Drill a small hole at the end of the crack to check it. Then tig weld the crack and hole with silicone bronze rod. Start at the outside edge and work towards the hole you drilled.
    I did a few this way a few years ago an it worked out pretty well.
    derek
    Jan 2013
    Awesome, thanks. Did you have any issues grinding and polishing afterwards?
    Aug 2006
    I knocked the weld down a bit but we (my friend I was doing it for) agreed it would be best to leave a bit of weld there.
Welding Cymbals
Welding Cymbals
