Welding Brazing Soldering Sealing
Page 1 of 17 123411 ... LastLast
Threads 1 to 20 of 327
Forum: Welding Brazing Soldering Sealing
Discuss Welding, Brazing, Soldering, Sealing technique's here.
  1. Need Help!- Airco 300 AC DC Heliwelder IV
    Started by Fordman76‎, 06-10-2016 10:00 PM
    01-04-2018, 06:50 PM Go to last post
  2. 12V HF HV Tig Box Design?
    Started by Tinkers-Au‎, 10-17-2017 05:09 PM
    240volt, box, models, search, tig
    10-18-2017, 01:52 PM Go to last post
  3. I screwed up real bad
    Started by outset‎, 09-28-2017 11:45 PM
    10-12-2017, 11:28 PM Go to last post
  4. Newbie- I want to learn how to weld - TIG?
    Started by FoxCNC1‎, 08-11-2017 05:04 PM
    ground, setup, steel, table, typical
    08-12-2017, 05:26 PM Go to last post
  5. Need Help!- 1095 spring steel welding
    Started by Pysiek‎, 07-25-2017 12:01 PM
    make, spring, steel, thick, weld
    07-25-2017, 12:01 PM Go to last post
  6. Need Help!- Arc Machine M415
    Started by Alex S.A‎, 07-11-2017 03:55 PM
    arc, clad, model, pipes, weld
    07-11-2017, 03:55 PM Go to last post
  7. Choice of a welder
    Started by zaebis‎, 02-22-2012 09:22 PM
    available, not
    05-22-2017, 12:53 AM Go to last post
  8. Copper sheet...solder or braze?
    Started by Ted383‎, 05-17-2013 01:04 PM
    03-18-2017, 01:21 AM Go to last post
    05-14-2016, 05:09 PM Go to last post
  9. Gas welding with propane?
    Started by rkremser‎, 06-10-2009 09:39 AM
    another, its, not, saying
    03-21-2016, 03:17 AM Go to last post
  10. Micro resistance/spot welding copper to brass
    Started by bongobill‎, 04-24-2015 12:07 PM
    brass, copper, rod, weld, welder
    12-11-2015, 10:49 AM Go to last post
  11. Glueing Aluminum to Aluminum
    Started by tooler82‎, 11-19-2015 12:32 PM
    aluminum, glue, piece, weatherstrip, yellow
    11-19-2015, 04:01 PM Go to last post
  12. Need Help!- Welding Beryllium copper pinch plates
    Started by dfearnow‎, 10-13-2015 03:07 PM
    10-13-2015, 09:34 PM Go to last post
  13. Video! Straightening Wire Trick for Tig Welding
    Started by adamprince2‎, 08-30-2015 12:56 PM
    straight, tig, video, welding, wire
    08-30-2015, 12:56 PM Go to last post
  14. Welding caused bend. How to straighten the square tube?
    Started by Azalin‎, 08-27-2015 07:44 AM
    axe, bend, jumping, straighten, tube
    08-27-2015, 10:40 AM Go to last post
  15. Semi-automated TIG setup for welding tubing
    Started by TheArmoury‎, 08-25-2011 10:41 AM
    its, look
    04-13-2015, 10:01 AM Go to last post
  16. PLASMA CUTTER - No Longer Available
    Started by ZEKE1‎, 03-03-2015 09:20 PM
    03-03-2015, 09:20 PM Go to last post
  17. Problem- Applying tungsten carbide/diamond grit/grains
    Started by Lene Madsen‎, 10-26-2012 04:49 AM
    already, maybe, since
    01-14-2015, 04:38 AM Go to last post
  18. My Homemade TIG welder
    Started by js530‎, 06-28-2006 01:46 AM
    16 Pages
    1 2 3 4 5 ... 16
    10-22-2014, 12:37 PM Go to last post
  19. Problem- Spot weld dresser cutter
    Started by klthmpsn1‎, 08-18-2014 06:32 AM
    #00, automatic, center, color, cut, cutter, dresser, electrode, electrodes, face, failure, good, problem, robot, size, spot, spot welding, tip, weld, welders, welding, work, working
    08-18-2014, 06:32 AM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 13 users browsing this forum. (0 members & 13 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
