It depends on what component suppliers you have access to, it is 10ohm and I would guess a minimum of 25watt.
You could sub any other manuf. product in a pinch, whether it has radial, axial or tab termination.
I need this resistor
By chonporting, shot with N96 at 2010-01-15
I need help does anybody know where to buy this resistor
This is from Fanuc Supply module
A06B-6110-H055
The rated output of this Fanuc power supply module is:
283-339V DC, 65KW
This power supply is from 330 tons Fanuc Roboshot injection molding sold by Cincinnati Milacron
I found some but they are very small and surface mount or thru hole
this one is screwed onto the board
Thanks Al_the_Man
