Results 1 to 5 of 5
Thread: Mach compatible CNC lathe
    Apr 2007
    Hey folks, I'm in the market for a Mach3 compatible CNC lathe. We've currently got a Jet 9x20 belt drive bench lathe and it's just a little too 'hobbyist' for our purposes. Would like to upgrade to CNC and get a little bit better quality speed control and potentially a slightly larger capacity.
    Our shop currently has a vertical mill and CNC table (router/plasma), which are controlled by Mach3. It would be great if we could use the same workflow with a new lathe.
    I'm being vague about specs because we'd like to buy the best thing we can afford. I think we're probably looking at sub $25k (not including tooling) for a budget. Is this realistic? Suggestions?
    Apr 2007
    I'm having trouble finding much (if any) information out there on Mach compatible lathes.
    As far as CNC machines, here's what I see so far:
    Microkinetics 1236 & 1340
    SmithyCNC 924 Lathe (Sieg C6)
    Syil C6 <-- Mach compatible
    Anyone have any suggestions for slightly more high end machines?
    Dec 2009
    China
    here is your required machines
    hello, I am Jessica from Taiwan How-Mau Machinery Co., Ltd. and our company specializes in producing cnc milling & lathe machines and we use Mach 3 software and G-code in all of our cnc lathe machines and I send you the pictures and spec of our cnc lathe machines and our company also specializes in producing cnc milling & lathe machines according to our customers' requirements and if you can list your spec, we can produce your own cnc lathe machines as we have 10 designers who have more than 10 years experience in designing.You are very luck as we are now having new year special sales for a month. If you have interests in our cnc lathe machines , you can tell me and I will give you the most comprehensive and the most competitive price.
    My contact information:
    Skype:twhowmau009
    MSN:kerry@diylife.com.tw
    Telephone:0632-5956608
    Fax:0632-5956609
    Mobile:13062061317
    Attached Thumbnails Attached Thumbnails Mach compatible CNC lathe-135c.jpg   Mach compatible CNC lathe-specification_hl-020.jpg   Mach compatible CNC lathe-hl-135c_s.jpg   Mach compatible CNC lathe-hl020sss.jpg
    Jun 2008
    If you're interested in a turnkey retrofitted 10x22, try d3cnc.com
    Jim
    No time to do it right, plenty of time to do it twice.
    Jun 2005
    honestly if your budget is 25000, then you are barking up the wrong tree looking for a hobby machine. i would look at something like a haas TL1 series. way more machine than any of the converted ones and they actually offer positional feedback to the control. but heck why stop there? for for 25k in the used cnc lathe market you can buy a nice hardinge cobra, or a nice nakamura, or a nice haas, or whatever. and you get the tool changer, coolant pumps, full enclosure, etc for free. now if your really limited on space, have a weight limitation, or a power limitation maybe these higher end units aren't for you.
    1. Will Mach 3 work with the new Sieg KC6 lathe?
      By squale in forum Mach Lathe
      Last Post: 12-16-2009, 02:09 AM
    2. drill setup in mach lathe
      By Runner4404spd in forum Mach Lathe
      Last Post: 01-05-2008, 07:57 AM
    3. Mach Turn with Phoenix Lathe
      By bkkpool in forum Mach Lathe
      Last Post: 11-09-2007, 07:06 PM
    4. Compatible HVAC software with Mach 3
      By Millerman in forum SheetCam
      Last Post: 09-08-2007, 07:00 PM
    5. Mach Lathe - Spindle Control How??
      By cjchands in forum Mach Software (ArtSoft software)
      Last Post: 04-05-2007, 11:21 AM
