Results 1 to 9 of 9
Thread: Best CNC mill for less than 5K
    Nov 2005
    Hey guys what is the best cnc mill for less than 5k not including tooling? Most of the work will be on pistol frames cutting hard steel. Doing engraving type work and milling serrations and grooves. I'm new to cnc and i am wanting to know what the industry standard for cad software is because i would like to learn that I really want a turn key mill with everything but a computer with software. After i make the cad software what other software do i need? Do i need some software to send the info to the mill? Sorry guys I'm really new to this so sorry for the questions.
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Post
    Outlaw,
    Why not CNC your ZAY7045FG, it would be fine for what you want to machine.
    You would not need to purchase scales or a DRO readout and could apply the saved money to the CNC conversion.
    You will need cad-cam software and Mach3.
    Are you going to just engrave on flat surfaces?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Nov 2005
    I have thought about cnc the lathemaster but i also need a manual mill and the way most of the conversion kits are it would make using the mill in a manual mode impractical. But if someone knows of a super easy drop in kit for the zay class mills i would love to see it. Most of the engraving would not be on a flat surface. I would also like full 3d capabilities some time down the road.
    Feb 2007
    U.S.A.
    Post
    Why not install a MPG, you can operate a CNC mill just like a manual mill.
    The only difference would be turning the MPG instead of a hand wheel.
    See the video below.
    "http://www.youtube.com/watch?v=CowMlr9F96I"]YouTube - MPG-Test with Mach3
    It would be much easier than cranking hand wheels too!
    Jeff...
    Feb 2009
    Quote Originally Posted by jalessi View Post
    Could you post a source for one of those? Looks pretty handy!
    Feb 2007
    U.S.A.
    Post
    CNC4PC has very innovative products and Arturo's customer service is awesome.
    Look near the bottom half of the web page.
    http://tinyurl.com/mtabgp
    Once I used a MPG I would never go back to manual machining in a traditional way.
    Jeff...
    Attached Thumbnails Attached Thumbnails Best CNC mill for less than 5K-mpg1_e.jpg   Best CNC mill for less than 5K-mpg2_.jpg   Best CNC mill for less than 5K-mpg3.jpg   Best CNC mill for less than 5K-mpg6.jpg
    Oct 2006
    Referenced Youtube mini-Mill?
    Jalessi or anyone, do you know make and model of the mill in the upthread attached youtube video?
    Not to common, an x table, y column, and a z head. Looks interesting and pretty stout for its size.
    Jul 2009
    Quote Originally Posted by outlaw paintbal View Post
    Gday
    Im in the same boat, looking for same answers,,
    Is the process CAD to mach 3 to mill.
    Outlaw i have been looking at the sieg KX3 mach3 (it also has option MPG)but it is hard getting straight answers somtimes.
    Feb 2007
    U.S.A.
    Post
    ROV CNC,
    Straight as a bent arrow.
    "Cad" to "CAM" to "Mach3"
    Jeff...
    1. Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head
      By fignoggle in forum Benchtop Machines
      Last Post: 05-12-2009, 12:11 AM
    2. Coming Down to the Taig Micro Mill or Grizzly Mini Mill.
      By SpeedsCustom in forum Taig Mills & Lathes
      Last Post: 01-23-2009, 12:14 AM
    3. Replies: 7
      Last Post: 01-21-2007, 08:56 PM
