Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Want To Buy...Need help!
Want To Buy...Need help! Post items that you are looking for so people can help you to find where to buy them.
Old 06-04-2009, 09:21 PM
askalot is on a distinguished road
Spindle Motor and ATC Required
i am a from australia and i have scratch built a cnc machine come router and i am looking for a spindle motor with the ability of a Auto tool changer.
the reason i want them combined in one unit is the size, i have looked at belt drive spindles and the head stock size of the machine really does not allow for both motor and spindle unit.
the spindle motor required specs are:-
1.5 - 2.0 Kw
4.75" or 120mm in Diameter
12" - 18" or 300 - 450mm Long ( But can be a little longer )
ISO or HSK (Not sure which one need help on best choice)
220 Volt Single phase
Low Rev's say 500 RPM
High Rev's say 30,000 RPM
Self Cooled
ATC Mechanism is air but is there an electronic one
Spindle to be mouted Vertically
so now the seach begins there is really no supplier of these types
Spindle motors in australia if there is they are not well advertised and i have been looking for 5 weeks.
Your help will be greatly appreciated in finding a supplier or some one who has gone down this path that could offer some of there wisdom.
Kind Regards
Askalot
Old 06-04-2009, 09:42 PM
ger21's Avatar
I don't think you'll find a spindle with a range of 500 to 30K rpm. Typical router spindle range is about 7000 - 24000 rpm.
Here's a US supplier of chinese spindles. But they're water cooled.
http://kelinginc.net/CNCSpindleandController.html
Old 06-06-2009, 03:10 AM
spindle motor and ATC required
Thanks Ger21 for your info, i went to the web address you gave and had a look, well i must say the price jumped considerably between manual to ATC the jump was $2000 dollars.
i think i might look at having a seprate motor with belt drive spindle ,the cost of those spindles i think might be less than $2000 dollars.
i have heard that sherline sell these spindles is this true ???
i have read a post on cnczone that a spindle motor was gained from a treadmill 2Hp - 0-11,000 rpm as any one heard how that went.
Still looking but i now will look at those manual spindles on the web site a lot closer to find which one the specs suit my needs.
Thanks again Ger21
Kind Regards
Askalot
Old 06-06-2009, 09:38 AM
ger21's Avatar
You might want to contact some of the chinese spindle sellers on Ebay. They can probably supply an ATC spindle, and probably at least $1000 less the the Keling's price.
Old 04-27-2010, 11:51 PM
PrecisionSpindl is on a distinguished road
High Speed Spindle
Have you found a spindle?
If you are still looking for a high speed spindle, you can contact -
Precision Spindle & Accessories Inc.
www.precisionspindleinc.com tel. 519 671 3911
haviland@precisionspindleinc.com fax. 519 652 5994
G320/G340 'Required Direction Setup' and 'Required Direction Hold' times? margni74 Gecko Drives 2 12-05-2008 09:10 PM
a paper shredder motor for spindle motor?? .xXACEXx. DIY-CNC Router Table Machines 4 06-02-2008 10:17 PM
Problem- TL 2 Spindle Motor Fan Peter Gibbs Haas Lathes 0 04-17-2008 07:01 AM
Servo motor used as spindle motor? fatal-exception General Metal Working Machines 6 09-14-2007 03:55 AM
more rpms for spindle motor and spindle bob1112 Mechanical Calculations/Engineering Design 33 02-10-2007 02:01 PM
