Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: Metal Spinning
    Apr 2009
    UK
    Metal Spinning
    Anyone know of a good place to get funnels spun (i only need the one), i've emailed a couple of companies, and will continue to do so.
    I get the impression many just dont want to know unless you are going to be sending thousands of £ their way, and wont even bother responding.
    Any advice is apreciated.
    Registered Donkey Hotey's Avatar
    Nov 2007
    In order to spin a funnel, they have to make a mandrel to shape it over. How much are you willing to spend on just one funnel? It's not that they don't want the work; it's that they know you won't pay the price necessary to make the tooling so they don't bother responding.
    Greg
    Apr 2009
    UK
    How do they know how much cash i have?
    Also as i understand it some companies can make tooling from a number of materials including wood for small runs.
    Turns out the only funnel close to my required specification that is available to purchase is $177/£119 which i think is a bit over the top for a mass produced item.
    Nov 2007
    Quote Originally Posted by eggman6 View Post
    I wouldn't make the mandrel for $177. That's why they won't answer you. They know you won't pay what it will really cost.
    What kind of ballpark figure do you think such a job is worth? I'll do the job for you but I'd be doing you a huge favor if I charged $500.
    Greg
    Jul 2005
    $177 seems a lot for a funnel. What are your dimensions/requirements.
    Apr 2009
    UK
    Quote Originally Posted by Donkey Hotey View Post
    I never told them how much i was willing to pay, so that doesn't explain why i haven't recieved a reply, they dont know i wont pay the cost.
    Also i experienced many non replys was when enquiring about a small enclosure a while back, that required no custom tooling.
    My under estimation for the cost is down to the fact i was unaware of the tooling required and was under the impression the only part needed was the shape that the metal is spun over, and being that wood can be used i thought that it wouldn't be too expensive. I wouldn't have considered spinning as an option if i knew large metal parts had to be machined for my job.
    To Geof,
    The funnel starts off as a cylinder with a diameter of 120mm, which is about 65mm tall, then tapers down to 35mm over a length of 80mm a total hieght of 145mm.
    So something like this
    Jul 2005
    I wondered about the size because sometimes it is cheaper to be unconventional and do something like machining from solid but obviously that is impractical for the size you need.
    $177 stills seems a lot if it is mass produced but getting a one-off would definitely be more. The hardwood alone for the mandrel would be a good portion of that sum.
    Have you considered seeing if a sheetmetal place could fabricate one?
    Apr 2009
    UK
    I will look into this.
    Apr 2008
    I would make one out of thin cardboard.Then lay it out on sheetmetal roll it n tig weld the transition between cone and cylinder.About 4 hours work @ $60.00 per hour.
    Good luck!
    Apr 2009
    UK
    4 hours? is that including your lunch break?
    I know i can get the welding done for no more than £30 (including the postage back to me)
    I may be able to get it cheaper but i can get the metal for around £20
    So thats $75 (very bad exchange rate at the moment)
    I cant imagine rolling the sheet metal taking all that long, hardly an extra $165/£110 worth of work.
    I could probably save more money if i can get an offcut of seamless tube for the cylindrical part.
    At $240 i could buy a sheet roller and just pay to get it welded and have a bit of cash to spare, then sell the roller on.
    Moderator HuFlungDung's Avatar
    Mar 2003
    By all means, have it and do as much as you can yourself. That is how lots of businesses get going, one guy figures he can do it more cheaply himself, or can do a better job himself.
    BTW, why would a customer expect to not pay for a lunch break, a coffee break and a 30% bonus for taxes off the top, as well as a percentage of the overhead costs such as knowing how to do what you want done, and for having accumulated a bunch of equipment and/or premises on which said equipment is situated and set up to do the work conveniently?
    Nov 2007
    Whoa! Hang on, you said spinning, not rolling. Make sure you're comparing apples to apples.
    You asked for a spun part. That implies a seamless part, made over a mandrel, usually from flat material but sometimes stretched from tube. This is the process you asked for:
    "http://www.youtube.com/watch?v=UP_gq1ahrmk"]YouTube - Metal spinning a light fixture
    If you now just want it fabricated any old way, yeah, you could just cut the pieces from sheet and weld them up. There is a huge difference in the quality, cost and appearance of the two methods. The welded piece probably won't be nearly as nice and it won't be seamless, but then maybe that doesn't matter. You haven't shared what you need this for, whether cosmetics matter or if it's going to have to carry pressure.
    Greg
  • Page 1 of 2 12 LastLast
    1. Metal Spinning
      By l u k e in forum General Metalwork Discussion
      Last Post: 04-07-2012, 11:00 AM
    2. Replies: 3
      Last Post: 11-20-2008, 01:38 PM
    3. Spinning Nut
      By Jason Marsha in forum DIY CNC Router Table Machines
      Last Post: 01-09-2008, 11:17 AM
    4. Bellmouth air intake metal spinning
      By smoregrava in forum General Metalwork Discussion
      Last Post: 04-07-2006, 09:21 AM
    5. Spinning nut
      By JFettig in forum Mechanical Calculations/Engineering Design
      Last Post: 10-17-2005, 07:47 PM
