We have a customer in China has big investment on heavy duty machining industry. They are looking for qualified manufacturers for below list of machines:
CNC Slideway Grinding Machine Working Table: 3000mm*8000mm
CNC Slideway Grinding Machine Working Table: 2000mm*5000mm
CNC Profile Grinding Machine Working Table: 2500mm*5000mm
CNC Floor-type Boring Machine Working Table bearing load: 80 ton
CNC Floor-type Boring Machine Working Table bearing load: 30 ton
CNC Horizontal Lathe Max working piece dia: 2500mm
CNC Vertical Lathe Max working piece dia: 8000mm
Bridge Turning/milling Combined Machining Center
Working Table: 5000mm*20000mm
Bridge Machining Center Working Table: 3500mm*10000mm
Bridge Machining Center Working Table: 8000mm*320000mm
Can anyone provide some suggestions on manufacturer selection (world wide)?
Thank you in advance.
ACLink
