Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Want To Buy...Need help!
Want To Buy...Need help! Post items that you are looking for so people can help you to find where to buy them.
Old 11-19-2008, 04:41 PM
ChicagoX55 is on a distinguished road
cant find a machine that does what I need it to do
I am looking for a machine and can't seem to find one that does what I need it to do.
I make billet parts for the marine industry. Currently none of these parts are painted, just anodized black. There are certain parts that require things to be written on them such as "on off" or a company name. As of now i just laser engrave these parts and it comes up white on the black. The problem is that I am going to start powder coating these parts different colors and some will be light so the laser method will not work. I am looking for a machine that can apply paint in small fonts, large fonts, and patterns if necessary in all colors. People have suggested pad or screen printing but that wont work, these products are for boats and have to be able to sustain the elements. It needs to be high quality and durable. Does anyone know of a machine that does this?
Thanks in advance!
John O
Old 11-19-2008, 07:06 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
Thanks in advance!
John O
I know there has been threads about laser engraving SS on a curve, something about using clay so the light doesn't reflect? Would something like that work? Could you just paint them a dark color or use some sort of coating for the purpsose of not reflecting the laser then strip the paint or coating after?
Do you own the laser? A shop with a more powerful laser say no problem.
Just an idea...
The parts will still be aluminum (or titanium since you mentioned anodizing), right?
Old 11-19-2008, 07:10 PM
I own the laser, that is not the problem. The problem is that when you laser the part it appears to be white (really aluminum). So if I was to laser lets say a yellow part you wouldnt really be able to see it. But it I had a durable black paint that was applied then you would. . .
Old 11-19-2008, 07:17 PM
^^^ another perspective! I didn't think that you wouldn't be able to see the laser engraved area against the light color. Sounds like you need to have them engraved. Sorry, going to be more expensive... Just tell your customer they have thier choice of black or black, that's the only two colors you offer.
Old 11-19-2008, 07:21 PM
On a more serious note, send them to someone for CNC milling/engraving. The RFQ section is great, sorta, some of the regulars either charge $200/hr or don't know what they are doing.
Old 11-20-2008, 07:41 AM
cut more is on a distinguished road
I have heard of Ink or something like it, that can be laser cured on a surface. I don't know what it was called, Just that it was used on metal to give a color contrast for lettering.
Sounds like what you are looking for.
Sorry I couldn't be of more help,
Cutmore
Old 11-20-2008, 08:37 AM
Fixittt is on a distinguished road
Just thinking out loud here, but could you not make a plate that rivets to the part with all the info lasered onto it?
Bright yellow part, Nice black name plate with laser engraving attached to the part with logos, and info......
Old 11-20-2008, 10:50 AM
I could on the larger items but you have to keep in mind that some of things things are pretty small. 2" x 3/4" in some cased so the text is tiny
Old 12-04-2008, 11:05 PM
NinerSevenTango is on a distinguished road
You could try laser engraving as usual and then wiping some epoxy paint over the finished work so that the powdercoated area ends up clean but the contrasting paint is in the engraved depression. Not sure if you'd need primer first. But DP90 epoxy primer covered with Sherwin Williams garage floor epoxy makes the most durable machine finish I've ever been able to come up with, enduring years of exposure to water and chemicals. It might be worth a test.
Need Help!- ...to find a machine or someone to build parts dabckid Want To Buy...Need help! 2 05-31-2008 04:25 AM
Where to find Detail Info of a 3D weaving carbon fiber machine ? Calico Composites, Exotic Metals etc 13 08-23-2007 11:25 PM
A lucky find, a good machine? TimKoene CNC Wood Router Project Log 29 12-04-2005 02:02 PM
Where can I find Good CNC Wood Cutting machine for Car parts size ? Calico DIY-CNC Router Table Machines 3 02-28-2005 12:36 AM
