Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Want To Buy...Need help!
Want To Buy...Need help! Post items that you are looking for so people can help you to find where to buy them.
Old 10-27-2008, 03:09 PM
LJG LJG is offline
LJG is on a distinguished road
DRO
Just bought a vertical mill with anilam dro. Very old display, first generation I think. I need to know if a later display will work with the scales I have. If a newer display will work, what do I need to do to convert and where can I find and newer display?
Thanks,
LJG
Old 10-27-2008, 03:43 PM
Al_The_Man's Avatar
It may require quite a bit of reverse engineering, it helps if you have the pin out of both the old and new DRO.
Even then, many modern DRO's the scale is graduated in metric divisions, the conversion to imperial is done in the DRO unit.
Also whether the new unit can be scaled to suit your old scale resolution.
You could hook them up to a PC like this:
http://www.lindsayengraving.com/othe...rests/dro.html
Old 10-29-2008, 03:11 PM
LJG LJG is offline
Thanks, I'll probably buy a new one. May sell the old anilam, the scales still work and the readouts work in mm but only one works in inches.
LJG
