| Want To Buy...Need help! Post items that you are looking for so people can help you to find where to buy them. |
Hello I need help in configuring a CNC setup. I am looking for a desktop 4-axis CNC machine to do some artwork. I would like to import some clipart and then draw that on a work piece (either a flat surface or a cylinder) Also, is there anyway to hook an automatic fluid dispenser to the CNC? I would appreciate recommendations for the CNC router and software. Thanks |
| Hi, Welcome to the zone. Please provide more information, such as material you would like to machine, size of work, diameter etc... A fluid dispenser to dispense glue, paint,oil....? What is you budget and how many hours a day will the machine be used? Is it for a hobby or commercial application? Your questions are a little to vague. The more you ask, the better we can inform or help. Jeff... |
| Hi Jeff Thanks for your response. I do not want to cut any material. I would like to draw/paint on a cylinder which could be made of wood or styrofoam. The fluid will be some paint or paste. The size of the cylinder will be about 6" diameter max. This is for hobby so it will be operational mostly on the weekends for few hours I do not have a good idea about the CNC cost.... however the machine should have very good tolerance to draw art on cylinder or a flat surface Thanks in advance Thanks |
how long is the drawings on the cylider going to be. A 6" diameter might get into problems with clearance under the cross beam on some of the smaller machines. www.cadcamcadcam.com has a few that might fit the bill. There are a bunch more suppliers. Of course it depends on what you have for a budget and what you want for accuracy, are you talking .001" which is very accurate for a router type machine, or .010" which is easy to get on a snall machine and is probably more than enough for what it sounds like you are doing. Depending on exactly what kind of flow you are looking it cold be easy or near impossible to hook up th efluid dispenser. If you have an electrical fluid dispenser already and you just need the computer to turn it on or off, that is easy. If you need to make something from scratch, then that is more difficult. Mike.
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| Wood, There is a big difference between paints and paste, now you are introducing a viscosity issue. Are the designs going to be used over and over or are you personalizing each one? As Mike stated mounting a pen or marker etc would be fairly easy, the paint or paste would require a special pen. See the link below. http://www.durablesupply.com/saksolpainst.html How long are the objects you want to embellish? MORE DETAILS! Jeff... |
The cylinders could be as long as 9 - 10" in length. thanks in advance |
| It will more than likely need to be X12 Y8 Z8 because you need a little room to get around the items. http://www.taigtools.com/cmill.html. with a sherline 4th axis. If all you are doing is 6" round parts and less than 5.5" flat parts you will be all set. On the round part all you really need to do is get to the middle of the part and stay there. The 4th axis rotates and the table will pretty much stay still. As you will not have any cutting force to speak of, you won't need a cast iron machine. I have a Taig and I can measure it if you are absolutly sure of the size of the parts you wan to make. How much are you looking to spend. A ready to run machine will be about 2K usd plus,plus,plus. Mike
#10
Thanks for the help. Which software will work with this setup (with sherline 4th axis) so that it can wrap a design around a cylinder ? Looking around I do see that 2k plus is the avg cost. thanks |
#11
| There are many other cam packages that will output 4 axix g-code and will work. Try and download the trial packages of a few and see which one works best 4 you. I use deskcnc daily and use mach 3 tp run 2 of my three machines. I am glad to help.
| Tags |
| cnc router |
| Tracing Artwork in CorelDRAW | jemmyell | General Metalwork Discussion | 0 | 03-10-2008 11:50 AM |
| Let's See Your Dolphin Artwork | TZ250 | Dolphin CADCAM | 10 | 02-11-2008 10:56 AM |
| artwork inserts??? | spock | Vacuum forming, Thermoforming Etc | 3 | 10-19-2007 10:19 AM |
| What Software For Cnc Plasma Artwork | DISCONNECTED | CNC Plasma and Waterjet Machines | 2 | 01-28-2007 03:34 PM |
| Artwork for Plasma Cutter cnc? | Crayola | CNC Plasma and Waterjet Machines | 1 | 06-14-2006 10:44 AM |
