| Want To Buy...Need help! Post items that you are looking for so people can help you to find where to buy them. |
Hey, I'm looking for a deep vise to I can mill the edges on plates of various material. It doesn't have to be a high quality vise or anything, a cheap important would serve my needs just fine. I'd just like something 4' deep or more. Thanks.
__________________ -JWB --We Ain't Building Pianos (TCNJ Baja 2008) |
![]() Or maybe it is a typo and you mean 4". I disagree with the; It doesn't have to be a high quality vise or anything... Get a good vise it will pay off in reduced frustration in the future. A Kurt 6" is a good choice because it is possible to hold material up to 12 inches wide, maybe wider, by putting the movable jaws on the outside. Kurts are also so rigid you can grip a short length in less than the jaw width and it will hold (not good practise but it works). Also it is possible to make tall custom jaws for gripping oddball stuff.
| Geof, Yeah 4' is a lil much. I I did mean 4". I have the 6" Kurt Vise but the Jaws are only 1 3/4" Deep so when I stand a few 6.5" plates in it, even with additional c-clamps they still vibrate quite a bit. So any suggestions on a vise with deeper jaws? I'm not looking for length or width. Just deep so I can mill plates. I understand I could just pack a bunch of thick steel between Jaws and the plates and C-Clamp em in but then I'll have to face down steel plates which I'm trying to avoid.
| Geof has the right idea about cutting some custom jaws which is a standard procedure in most shops , there are 2 bolts holding each jaw on your kurt , duplicate the pattern on some steel stock other than that you can plan to spend a small fortune for a vise with those specs have you concidered bolting an aluminum plate to the table and hold the plates with some hold down clamps , then you can side mill with no vibration
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| Bite the bullet; make yourself some custom steel jaws to do what you need. Don't fall into the trap which I, and many people, sometimes fall into; saying to yourself it is just one job I don't want to spend a bunch of time making custom holders. Make the 'custom' stuff which in the case of vise jaws is 'general purpose' custom. You may not recoup the time spent on making the jaws the first time you use them but very soon you will have saved much more time than you spent.
| In deep SH%$ | stevo1 | Fanuc | 3 | 08-28-2008 12:51 PM |
| how deep will it cut? | anakinjay | Rockcliff Machine | 2 | 11-02-2007 09:22 AM |
| TM-1 vise | maxine | Haas Mills | 6 | 10-19-2007 07:34 PM |
| Home Made Vise Stop - For 6" Kurt Vise | widgitmaster | Bridgeport and Hardinge Mills | 20 | 12-15-2006 09:49 AM |
| .250 Dia x 22.00 deep ?? | Rekd | Machine Problems, Solutions , Wireless DNC, serial port | 10 | 02-25-2005 09:24 AM |
