Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Want To Buy...Need help!
Want To Buy...Need help! Post items that you are looking for so people can help you to find where to buy them.
Old 09-17-2008, 10:28 PM
jncues is on a distinguished road
need help
I'm a new member and I need some help. I purchased a Taig cnc mill about three years ago. It performes very well. I want to add the 4th axis and have encountered all sorts of unknowns. First, the controllers were made by Industrial Devices Corporation, model S5102, and are no longer in prodution. Second, the stepper motors are Vexta PH266-E1.2, which are no longer made. They are 8 wire motors going to 4 pins on the controller. The controller is labeled A+, A-, B+, B- and GND. The motors are labeled as 2 phase, 1.8 deg, 5 ohm, 1.2A. What little information I find about the controller is that it is current adjustable via resistor from 0 to 7 amps at 75 VDC. I need more torque than the nema 23 Vexta PH266's produce. What nema 23 motor is availabe that will run with these controllers with approx. 200 + in/oz of torque?
Old 10-06-2008, 07:49 AM
ezcncjohn is on a distinguished road
help for vexta
the vexta motors are still avaiable.
sounds like you need a 3 stack hybrid motor to get the torque you need. Using to a more powerful drive and power supply will help greatly too. call ezcnc, they can help you out. 214 924-0314.
hobby machines like you have are great: but being inexpensive, they lack powerful motors, drives, and efficent/accurate screws that an industrial machine will have as standard equip. Fortunatly, you have a good base to start from, and it can be made to perform very well if you are willing to invest a few bucks.
Old 10-07-2008, 06:08 PM
awerby is on a distinguished road
Does the controller have a 4th axis channel?
It doesn't sound like any standard Taig system, so you probably have a third-party controller on it. If you've got 4 channels, it shouldn't be difficult to add another motor. If not, if you don't mind doing some re-patching before doing 4-axis jobs, you can probably get it to work by switching the Y axis over to A, since you can do some kinds of rotary milling from a fixed Y position. Adding a channel to a defunct controller sounds like a thankless chore. You might consider scrapping the old controller system (you could put it in the Classified section of this site) and getting a new one that supports 4 axes - the new G540 from Geckodrives sounds like a good candidate.
It shouldn't be too hard to find a motor that will work for the 4th axis; you don't really need a lot of torque (what made you think you did?), but speed helps, since you've got some gearing to compensate for. Motors with lower holding torque often have lower inductance as well, which makes them more responsive. I'm assuming you are planning to use a rotary table,right? While I've seen "4-axis" machines on Ebay that simply hang a chuck on a stepper motor, that's not really recommended...]
Andrew Werby
www.computersculpture.com
Old 10-07-2008, 08:21 PM
Thanks for the information. I have finally found the technical information on the drives. IDC made them with Parker Compumotor drive modules and their own power supply. I purchased a 282 oz/in motor with 8 wires and hooked it up in paralles and changed the resistor in the drive to put out 4 amps and it runs great and does not get hot unless it runs for a long time. The drive has a selectable current idle state after one second with no pulse. It wakes up on a pulse command. I think the drives, which are a pair of dual chanels, are really good even though they are 1995 vintage.
I am located in Dallas also and I make pool cues with inlays using the cnc mill.
Regards,
John
