Results 1 to 10 of 10
Thread: orientation mag sensor
    Jul 2007
    australia
    Desperately trying to locate a 2nd hand
    Fanuc magnetic orientation sensor.
    Possibly out of a retired machine being broken down for spares.
    We dont require the amplifier just the sensor.
    P/N A57L-0001-0037.
    regards
    Matt
    Registered tahlinc's Avatar
    May 2003
    Tucson, AZ USA
    A57L-0001-0037
    We have the sensor but need the preamp!
    Jim
    Jim Short
    www.tahlinc.com
    Sep 2004
    I have an old sensor and pre-amp that I removed when I replaced the spindle motor and drive with different units. Spindle orientation was working prior to the retrofit, so I assume that the sensor and the pre-amp are both functioning.
    Unfortunately, neither have any identifying marks. The decal on the pre-amp has long since lost all of it's text and the portion of the decal that contains the part number on the back of the sensor has been rubbed off by the mounting bracket.
    If you're interested, snap a few pics of what you have and send them my way for comparison. Also, the orientation PCB in my machine was an A20B-0008-0030/02 unit; if you have the same PCB, there's a good chance that your sensor is the same.
    Chris Kirchen
    May 2003
    Tucson, AZ USA
    A57L-0001-0037-C
    The sensor is for a Kitamura Fanuc OMC.
    Jim
    520-403-9002
    Attached Thumbnails Attached Thumbnails orientation mag sensor-a57l00010037.pdf
    Jim Short
    www.tahlinc.com
    Sep 2004
    That's what mine looks like, except mine is a lot dirtier... I guess the only question is if there was more than one model that used the same enclosure.
    Mine came out of a Roku Fanuc 6MB milling machine. Do you have a number on the PCB?
    Chris Kirchen
    May 2003
    Tucson, AZ USA
    I will check tomorrow.
    Jim Short
    www.tahlinc.com
    May 2003
    Tucson, AZ USA
    I do not have that board.
    Sorry.
    Jim Short
    www.tahlinc.com
    Aug 2006
    We should have this in stock if you still need it. Please contact me if you are interested.
    Aug 2010
    australia
    Magnetic sensor
    Hi
    I am also looking fanuc magnetic sensor for my kitamura mycenter2. This is for spindle orientation. The part number is A57L-0001-0037. Pl inform where i can buy this part (new or second hand).
    May 2003
    Tucson, AZ USA
    Look on ebay
    Jim Short
    www.tahlinc.com
    1. Hall sensor connection
      By rainman in forum General Electronics Discussion
      Last Post: 01-09-2008, 08:13 AM
    2. Vibration sensor
      By efrag in forum Mach Wizards, Macros, & Addons
      Last Post: 12-27-2007, 11:08 AM
    3. magnetic sensor
      By keithmech in forum General Electronics Discussion
      Last Post: 07-28-2007, 07:04 PM
    4. non ARC height sensor
      By sunmix in forum General Electronics Discussion
      Last Post: 11-05-2006, 12:51 PM
    5. Optical sensor...
      By aghobby in forum DIY CNC Router Table Machines
      Last Post: 09-08-2004, 12:17 PM
