Results 1 to 4 of 4
Thread: Small CNC Router needed
    Mar 2008
    I'm wanting to make balsa wood crankbaits with a cnc router. Needs to cut lexan & circuit board parts and aluminuim on occasion. I have no experience with cnc nor any cad/cam software. I need easy programming & small cnc router. Looking for a complete package & durablity. Will probe software help with duplication ?? Would a 3d laser "probe" be a better solution?......What software would be best for making mutiples from one piece of stock? ......I thought that a "sign" program might works for making pairs of the same part, possibly 6 to 10 pairs per run. WHERE does a newbie begin getting educated??? I need started in the right direction/foot. Thanks Slope*n_c
    Feb 2008
    Google Carvewrite for a CNC router under 2 grand. Sears sells the same machine called Compucrve. Save two hundred bucks by shopping on line.
    May 2008
    Find what you werws looking for?
    Did you get what you need?
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    http://cgi.ebay.com/Precision-Mini-C...QQcmdZViewItem
    this would be great for crankbaits and such
    WidgitMaster is is a well respected member in these forums , if you search the forums you can find the build log on this line of routers
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    http://microcarve.microcarve.biz/
  1. Small 3D Pocket? help needed.
    By kprice1658 in forum General Metalwork Discussion
    Last Post: 09-07-2007, 11:47 PM
  2. Small Lot of Aluminum Castings Needed
    By stang5197 in forum Employment Opportunity
    Last Post: 01-02-2006, 08:21 PM
  3. Small Milled Plate Needed Qty. 20
    Last Post: 12-14-2005, 10:17 AM
  4. small woodworking job needed
    By cxixer in forum Employment Opportunity
    Last Post: 09-21-2005, 04:43 PM
  5. RFQ small parts needed
    By CNC Darren in forum Employment Opportunity
    Last Post: 02-23-2005, 11:49 AM
