| Want To Buy...Need help! Post items that you are looking for so people can help you to find where to buy them. |
| Need Help Looking to buy CNC lathe or convert a manual Hi New here and to CNC. I run manual machines and have to automate as I want to do all work in house. I have not run a cnc and will be getting training but I want to either buy a used cnc lathe (I do all small work) or convert a manual 12x36 lathe to cnc. I was also looking into converting a 7x20 as it already had a VS motor/spindle. I know this is vague but I do not know what questions to ask nor do I have basic knowledge with cnc. My wallet is bare so I need to do something for 5K or less. I saw a number of cnc lathes on ebay for under 5k but again I have no clue what I was looking at. Thanks |
| A VS spindle is not necessarily capable of CNC operation, it depends on what operations you want to do. Ideally the spindle should have good speed control regardless of load, this usually means feedback of some kind from motor to drive, if threading or CSF is required, an encoder is needed on the spindle. If you buy used, make sure it is a make that the controller is still supported, e.g. Mitsubishi Mazak Fanuc Fagor etc. or at least the manuf is still in bus. There is quite a bit mechanically to retro-fitting a manual m/c, ball screw, motor mounts etc. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| manual lathe convert cnc/manual lathe | kakayo | Vertical Mill, Lathe Project Log | 3 | 02-21-2010 02:13 PM |
| How to convert Manual Lathe to CNC Lathe? | zaid | General Metal Working Machines | 4 | 02-07-2008 01:42 AM |
| Convert Taig Mill into lathe? | youthebest | Taig Mills & Lathes | 4 | 11-19-2007 09:26 PM |
| Lathe: convert PULLEY to GEAR? | lepton | Mechanical Calculations/Engineering Design | 0 | 12-13-2005 12:22 PM |
| Lathe:convert PULLEY to GEAR? | lepton | Mini Lathe | 0 | 12-13-2005 12:19 PM |
